HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.6.2
* switched to new SDK 7.2.1
* added devices: Approach S7 42mm, Descent Mk3 43mm /Mk3i 43mm, Descent Mk3i 51mm, Edge 1050, epix Pro Gen2 42mm, epix Pro Gen2 47mm / quatix 7 pro, epix Pro Gen2 51mm / D2 mach 1 pro / tactix 7
Fenix 7 Pro, Fenix 7 Pro Solar, Fenix 7S Pro, Fenix 7X Pro, Fenix 7xPro Solar, Forerunner 165, Forerunner 165M, Venu 3, Venu 3S, Vivoactive 5
3.5.1
* switched to new SDK 4.2.4
* added devices: FR265, FR265S, FR965, GPSMAP 67/67i, Marq (Gen 2), Marq (Gen 2) Aviator, EDGE 540, EDGE 840, Instinct 2x Solar
* added two new font types GLANCE, GLANCENR (only available if device supports it!)
for full releasenotes see: releasenotes.txt
  • Pacer setting must either be in the format T2:05:00 or P5:30
    T means target time (here 2 hours 5 mins)
    P means target pace (here 5:30 min/km)
  • Hello, I send my XML as requested.
    <?xml version="1.0" encoding="UTF-8"?>
    <DIYLayout>
        <Device name="Forerunner 645 Music"/>
        <Designer time="07.06.2021 06:51" ver="3.2.1" ifver="C"/>
        <LayoutElement type="1" color="FFFFFF" x="120" y="120" x2="0" y2="0" eletype="CF" valuetype="FX" minval="false" maxonly="false" daynight="true" radius="120" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFA" x="0" y="0" x2="228" y2="39" eletype="RF" valuetype="HR" minval="false" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFA" x="0" y="206" x2="240" y2="240" eletype="RF" valuetype="HR" minval="false" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="0099C0" x="85" y="39" x2="85" y2="152" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="0099C0" x="155" y="39" x2="155" y2="152" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="0099C0" x="122" y="152" x2="122" y2="206" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="0099C0" x="0" y="98" x2="240" y2="98" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="0099C0" x="0" y="152" x2="236" y2="152" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="0099C0" x="0" y="39" x2="240" y2="39" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="0099C0" x="0" y="206" x2="206" y2="206" eletype="LN" valuetype="FX" minval="false" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="56" y="39" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="Ritmo" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="44" y="94" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="Desnivel" font="S_TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="120" y="39" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="Tiempo" font="S_TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="120" y="94" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="Hora" font="S_TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="186" y="39" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="+/-" font="S_TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="197" y="94" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="R medio" font="S_TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="72" y="149" fixedtext="true" maxonly="false" daynight="true" eletype="FX" text="T vuelta" font="S_TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="173" y="149" fixedtext="true" maxonly="false" daynight="true" eletype="DS" text="Distancia" font="S_TINY" halignment="1" precision="0" nr_values="1" sampletext="12.56"/>
        <LayoutElement type="0" color="000000" x="120" y="63" fixedtext="false" maxonly="false" daynight="true" eletype="ET" text="$M:$S" font="S_MEDIUM" halignment="1" precision="1" nr_values="1" sampletext="f"/>
        <LayoutElement type="0" color="000000" x="83" y="63" fixedtext="false" maxonly="false" daynight="true" eletype="CP" text="$M:$S" font="S_MEDIUM" halignment="0" precision="0" nr_values="1" sampletext="1000"/>
        <LayoutElement type="0" color="000000" x="118" y="117" fixedtext="false" maxonly="false" daynight="true" eletype="CT" text=" $H:$M" font="S_MEDIUM" halignment="1" precision="0" nr_values="4" sampletext="f"/>
        <LayoutElement type="0" color="000000" x="43" y="117" fixedtext="false" maxonly="false" daynight="true" eletype="TA" text="$V" font="S_LARGE" halignment="1" precision="0" nr_values="1" sampletext="9999"/>
        <LayoutElement type="0" color="000000" x="189" y="63" fixedtext="false" maxonly="false" daynight="true" eletype="PE" text="$m:$S" font="S_MEDIUM" halignment="1" precision="0" nr_values="10" sampletext="1323"/>
        <LayoutElement type="0" color="000000" x="0" y="0" fixedtext="false" maxonly="false" daynight="true" eletype="PA" text="$V" font="XTINY" halignment="2" precision="0" nr_values="30" sampletext="12.45"/>
        <LayoutElement type="0" color="000000" x="195" y="117" fixedtext="false" maxonly="false" daynight="true" eletype="AP" text="$M:$S" font="S_LARGE" halignment="1" precision="0" nr_values="3" sampletext="254"/>
        <LayoutElement type="0" color="000000" x="78" y="172" fixedtext="false" maxonly="false" daynight="true" eletype="LT" text="$M:$S" font="S_LARGE" halignment="1" precision="1" nr_values="1" sampletext="1326"/>
        <LayoutElement type="0" color="000000" x="166" y="172" fixedtext="false" maxonly="false" daynight="true" eletype="DS" text="$V" font="S_LARGE" halignment="1" precision="2" nr_values="2" sampletext="12.56"/>
        <LayoutElement type="0" color="000000" x="128" y="6" fixedtext="false" maxonly="false" daynight="false" eletype="HR" text="$V" font="S_LARGE" halignment="0" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="000000" x="125" y="202" fixedtext="false" maxonly="false" daynight="false" eletype="AH" text="$V" font="S_MEDIUM" halignment="0" precision="0" nr_values="1" sampletext="154"/>
        <LayoutElement type="0" color="000000" x="148" y="6" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="Fc" font="S_LARGE" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="145" y="202" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="Fm" font="S_MEDIUM" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="2" replDC="FFFFFA" valDC00="1710" colDC00="FF0000" hideDC00="false" blinkDC00="true" valDC01="1620" colDC01="FF6600" hideDC01="false" blinkDC01="false" valDC02="1510" colDC02="00FF00" hideDC02="false" blinkDC02="false" valDC03="1360" colDC03="00FFFF" hideDC03="false" blinkDC03="false" valDC04="1110" colDC04="C0C0C0" hideDC04="false" blinkDC04="false" invertcolor="false"/>
    </DIYLayout>
  • Whats your pacer config string?
    Should be:
  • Now I don't have the clock and I'm working, but what do you want me to tell you about the application settings?
  • but what do you want me to tell you about the application settings?
    Please read page 33 of the Guidance.pdf (on top of this thread).
  • Solved !!!. It put P03: 50 and it had to put P3: 50.
    Thanks at 2 !!!.
    Right now I delete my comment and give it 5 stars for this great data field.
  • Hello, adv. Cadence is not working well on my fr645 music watch, I have done tests with the native that Garmin brings and it marks half its field than the native Garmin.
    Garmin = 180
    DIY = 90
  • Which cadence sensor are you using? It sounds like you are referring to running cadence, so as the DIY value is half the Garmin value I'm wondering if there's something peculiar about running cadence that means the native garmin datafield displays it correctly but DIY doesn't
  • I don't use any cadence sensor, I only use the one for the clock, That is why I did the test of your application with the field that the clock has and it caught my attention that the data of your application is just half that of the Garmin data field. With the current cadence field it does not pass, that if you mark it correctly.
    Thanks.
  • Just for the record it isn't my application. I'm just a user like yourself that is trying to help.
    Only the app developer would be able to give you a definitive answer though I have a feeling that the watch accelerometer data used by the watch to determine cadence is different to what is presented to the CIQ application or the watch is manipulating the data to determine the cadence, which means that the cadence on DIY is reading half what the garmin datafield is reporting
