HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.9.1
* switched to new SDK 9.3.0
* added devices: Approach S72 43mm, Approach S72 47mm, D2 Mach 2 Pro, Edge 1060, Edge Explore 3, Edge Explore 3 Plus, Enduro 4, fenix 9 43mm, fenix 9 47mm, fenix 9 Pro 43mm, fenix 9 Pro 47mm, fenix 9 Pro 51mm,
fenix 9 Pro Solar 47mm, fenix 9 Pro Solar 51mm, Forerunner 70, Forerunner 170, Forerunner 170 Music, MARQ (Gen 3)
3.8.3
* fixed problem with backslash in configuration string
3.8.1
* switched to new SDK 8.3.0
* added devices: Approach S50, D2 Mach 2, Descent G2, Edge 550, Edge 850, Edge MTB, eTrex Touch, fēnix 8 Pro 47mm / 51mm / MicroLED, Forerunner 970, Forerunner 570 42mm, Forerunner 570 47mm,
GPSMAP H1, Instinct 3 AMOLED 45mm, Instinct 3 AMOLED 50mm, Instinct 3 Solar 45mm / 50mm, Instinct Crossover AMOLED, Instinct E 40mm, Instinct E 45mm, Venu 4 41mm, Venu 4 45mm / D2 Air X15, Venu X1, vívoactive 6
for full releasenotes see: releasenotes.txt
  • Hi
    As I posted, I had no time to match the fonts for all devices. You will have to adjust the fonts.txt file so it matches best your watch.
    Here are two xml files with all the fonts available. You will have to adjust the font type, size, and the 3 x-offsets for every alignment and the y offset. A short description is in the fonts.txt file.
    font_test1.xml
    font_test2.xml
    Just load the first xml file, copy the string to the settings of your watch and then compare your watch with the designer and adjust the fonts.txt file.
    If you change fonts.txt you will have to restart the designer!
    Because there are over a thousand font combinations for all devices it will just take time to adjust them all...
    regards
    Erich
    Hi,
    thanks a lot for adding of current lap pace.
    I have a further question. On the FR the place is limited. Therefore I want only show the pace up to 9:59min/km or similar to save space. Is this possible? In the old DIY I used a white rectangle over the first number (if bigger than 10min/km). But in your app that doesn't work.
    Maybe there is another solution.
    Thanks
    Christian
  • Hi
    At the moment, all graphics are drawn first and over them are the texts drawn, so your solution is not possible.
    I wanted to limit the pace over 10 anyway, because it is not really precise over that value.
    Will add that check in the next release.
    regards
    Erich
    Former Member in reply to hundsmiachn
    Sounds good, then I'm waiting for the next release.
    Christian
  • And once again - thank you very much for your work!
    A question on the side:
    With version 1.1.2 we got the possibility to define several strings. But if I want to use several DIY data fields in one activity profile, I think that doesn't help? So it would need clones of the app - right?
    From the name "DIY #1" I guess that this is planned after reaching a „end development level“?
  • Thanks for the tip. I'll give it a tryThumbsup
  • Enjoying trying out the new features.
    On my training ride tonight I noticed some differences with the Lap Time/Lap Number information in the app compared to the native Garmin datafields & thought I'd ask if this was intentional
    In the Garmin datafields the Lap Number begins at 0 when the start button is pressed & the Lap Time starts to count up. The Lap Number only increments & Lap Time reset when either the Lap Button is pressed or if in an interval workout; on completion of each interval. Stopping & Starting the timer has no effect on either the Lap Number or Lap Time other than pausing it while the timer is stopped.
    In the DIY datafield the Lap Number is initially 0, however when the start button is pressed the Lap Number increments & the Lap Time starts to count up. The Lap Number then increments & Lap Time reset only when the Lap Button is pressed it doesn't increment if in an interval workout when each interval is completed. Stopping & Starting the timer also causes the Lap Number increment & resets the Lap Time.
    I was thinking that maybe these differences are due to restrictions imposed by the functions made available to CIQ developers, but thought I'd ask
