HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.9.1
* switched to new SDK 9.3.0
* added devices: Approach S72 43mm, Approach S72 47mm, D2 Mach 2 Pro, Edge 1060, Edge Explore 3, Edge Explore 3 Plus, Enduro 4, fenix 9 43mm, fenix 9 47mm, fenix 9 Pro 43mm, fenix 9 Pro 47mm, fenix 9 Pro 51mm,
fenix 9 Pro Solar 47mm, fenix 9 Pro Solar 51mm, Forerunner 70, Forerunner 170, Forerunner 170 Music, MARQ (Gen 3)
3.8.3
* fixed problem with backslash in configuration string
3.8.1
* switched to new SDK 8.3.0
* added devices: Approach S50, D2 Mach 2, Descent G2, Edge 550, Edge 850, Edge MTB, eTrex Touch, fēnix 8 Pro 47mm / 51mm / MicroLED, Forerunner 970, Forerunner 570 42mm, Forerunner 570 47mm,
GPSMAP H1, Instinct 3 AMOLED 45mm, Instinct 3 AMOLED 50mm, Instinct 3 Solar 45mm / 50mm, Instinct Crossover AMOLED, Instinct E 40mm, Instinct E 45mm, Venu 4 41mm, Venu 4 45mm / D2 Air X15, Venu X1, vívoactive 6
for full releasenotes see: releasenotes.txt
  • <?xml version="1.0" encoding="UTF-8"?>
    <DIYLayout>
        <Device name="Edge 1030"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="0" x2="282" y2="470" eletype="RF" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="3" text="***   DATAFIELD LINES   ***"/>
        <LayoutElement type="1" color="000000" x="0" y="117" x2="282" y2="117" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="70" x2="278" y2="70" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="175" x2="282" y2="175" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="346" x2="282" y2="346" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="141" y="118" x2="141" y2="175" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="412" x2="286" y2="412" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="3" text="***   BATTERY   ***"/>
        <LayoutElement type="1" color="000000" x="14" y="15" x2="46" y2="29" eletype="RF" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="46" y="18" x2="50" y2="26" eletype="RF" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="16" y="17" x2="44" y2="27" eletype="RF" valuetype="BV" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="16" y="17" x2="19" y2="27" eletype="RF" valuetype="BV" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="00B001" x="16" y="17" x2="44" y2="27" eletype="RH" valuetype="BV" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="00B001" valDC00="1000" colDC00="00E000" hideDC00="false" blinkDC00="false" valDC01="200" colDC01="00E000" hideDC01="false" blinkDC01="false" valDC02="110" colDC02="F8C840" hideDC02="false" blinkDC02="false" valDC03="1" colDC03="FF0000" hideDC03="false" blinkDC03="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="38" y="33" fixedtext="false" maxonly="false" daynight="false" eletype="BV" text="$V" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext="87"/>
        <LayoutElement type="0" color="000000" x="38" y="33" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="%" font="SMALL" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="***   DATA FIELS IN UPPER REGION   ***"/>
        <LayoutElement type="0" color="000000" x="212" y="29" fixedtext="false" maxonly="false" daynight="false" eletype="CC" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext="167.34"/>
        <LayoutElement type="0" color="000000" x="235" y="34" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="rpm" font="TINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="135" y="19" fixedtext="false" maxonly="false" daynight="false" eletype="CS" text="$V" font="NR_HOT" halignment="1" precision="1" nr_values="1" sampletext="45.34"/>
        <LayoutElement type="0" color="8080FF" x="123" y="79" fixedtext="false" maxonly="false" daynight="false" eletype="AS" text="$V" font="NR_MILD" halignment="0" precision="1" nr_values="1" sampletext="34.76"/>
        <LayoutElement type="0" color="000000" x="56" y="82" fixedtext="true" maxonly="false" daynight="false" eletype="AS" text="vel.media" font="XTINY" halignment="0" precision="1" nr_values="1" sampletext="34.76"/>
        <LayoutElement type="0" color="000000" x="124" y="82" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="km/h" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="183" y="82" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="vel.max." font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="8080FF" x="241" y="79" fixedtext="false" maxonly="false" daynight="false" eletype="MS" text="$V" font="NR_MILD" halignment="0" precision="0" nr_values="1" sampletext="65.34"/>
        <LayoutElement type="0" color="000000" x="272" y="82" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="km/h" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="***   TIMER AND DISTANCE   ***"/>
        <LayoutElement type="0" color="000000" x="10" y="124" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="Tiempo en movimiento" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="182" y="124" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="Distancia" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="138" y="143" fixedtext="false" maxonly="false" daynight="false" eletype="ET" text="$H:$M:$S" font="NR_MILD" halignment="0" precision="0" nr_values="1" sampletext="3356"/>
        <LayoutElement type="0" color="000000" x="238" y="143" fixedtext="false" maxonly="false" daynight="false" eletype="DS" text="$V" font="NR_MILD" halignment="0" precision="1" nr_values="1" sampletext="12.56"/>
        <LayoutElement type="0" color="000000" x="256" y="151" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="km" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="***   TRAININGS EFFEKT   ***"/>
        <LayoutElement type="1" color="000000" x="0" y="445" x2="101" y2="445" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="101" y="413" x2="101" y2="469" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="33" y="444" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="TE" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="44" y="444" fixedtext="false" maxonly="false" daynight="false" eletype="TE" text="$V" font="SMALL" halignment="2" precision="1" nr_values="1" sampletext="4.2"/>
        <LayoutElement type="3" text="***   HEARTRATE   ***"/>
        <LayoutElement type="1" color="FFFFF3" x="48" y="416" x2="89" y2="443" eletype="RF" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FFFFF3" valDC00="1740" colDC00="FF80C0" hideDC00="false" blinkDC00="false" valDC01="1560" colDC01="FF8081" hideDC01="false" blinkDC01="false" valDC02="1390" colDC02="00F501" hideDC02="false" blinkDC02="false" valDC03="1220" colDC03="38C8F9" hideDC03="false" blinkDC03="false" valDC04="1040" colDC04="C0C0C1" hideDC04="false" blinkDC04="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="67" y="413" fixedtext="false" maxonly="false" daynight="false" eletype="HR" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="000000" x="23" y="418" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="hr" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="***   DATA FIELS IN BOTTOM REGION   ***"/>
        <LayoutElement type="0" color="000000" x="9" y="185" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="WATTS" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="1" color="FFFFF1" x="75" y="180" x2="117" y2="210" eletype="RF" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FFFFF1" valDC00="5000" colDC00="8080FF" hideDC00="false" blinkDC00="false" valDC01="3730" colDC01="FF00FF" hideDC01="false" blinkDC01="false" valDC02="2980" colDC02="FF8080" hideDC02="false" blinkDC02="false" valDC03="2610" colDC03="00FF00" hideDC03="false" blinkDC03="false" valDC04="2240" colDC04="00FFFF" hideDC04="false" blinkDC04="false" valDC05="1860" colDC05="FFFF00" hideDC05="false" blinkDC05="false" valDC06="1360" colDC06="C0C0C0" hideDC06="false" blinkDC06="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="95" y="179" fixedtext="false" maxonly="false" daynight="false" eletype="CB" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext="455.34"/>
        <LayoutElement type="0" color="000000" x="205" y="185" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="% FTP" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="255" y="179" fixedtext="false" maxonly="false" daynight="false" eletype="FT" text="$V" font="NR_MILD" halignment="0" precision="0" nr_values="1" sampletext="78.13"/>
        <LayoutElement type="3" text="***   HR-ZONE % BARS   ***"/>
        <LayoutElement type="3" text="***   Zone 1 ***"/>
        <LayoutElement type="1" color="C0C0C1" x="6" y="350" x2="60" y2="410" eletype="RV" valuetype="P1" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="34" y="387" fixedtext="false" maxonly="false" daynight="false" eletype="P1" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="25"/>
        <LayoutElement type="2" replDC="C0C0C1" valDC00="1000" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="C0C0C0" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="3" text="***   Zone 2   ***"/>
        <LayoutElement type="1" color="38C8F9" x="61" y="350" x2="115" y2="410" eletype="RV" valuetype="P2" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="88" y="387" fixedtext="false" maxonly="false" daynight="false" eletype="P2" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="10"/>
        <LayoutElement type="2" replDC="38C8F9" valDC00="1000" colDC00="38C8F8" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="38C8F8" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="3" text="***   Zone 3 ***"/>
        <LayoutElement type="1" color="00F501" x="116" y="350" x2="169" y2="410" eletype="RV" valuetype="P3" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="144" y="387" fixedtext="false" maxonly="false" daynight="false" eletype="P3" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="18"/>
        <LayoutElement type="2" replDC="00F501" valDC00="1000" colDC00="00F500" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="00F500" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="3" text="***   Zone 4   ***"/>
        <LayoutElement type="1" color="FF8081" x="170" y="350" x2="224" y2="410" eletype="RV" valuetype="P4" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="203" y="387" fixedtext="false" maxonly="false" daynight="false" eletype="P4" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="13"/>
        <LayoutElement type="2" replDC="FF8081" valDC00="1000" colDC00="FF8080" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="FF8080" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="3" text="***   Zone 5   ***"/>
        <LayoutElement type="1" color="FF80C0" x="225" y="350" x2="276" y2="410" eletype="RV" valuetype="P5" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="248" y="387" fixedtext="false" maxonly="false" daynight="false" eletype="P5" text="$V %" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="19"/>
        <LayoutElement type="2" replDC="FF80C0" valDC00="1000" colDC00="FF80C0" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="FF80C0" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="3" text="*** WATTS ZONE ***"/>
        <LayoutElement type="3" text="***  Zone 0 ***"/>
        <LayoutElement type="1" color="C0C0C0" x="3" y="215" x2="44" y2="343" eletype="RV" valuetype="S0" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C0" valDC00="1000" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="C0C0C0" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="50" y="289" fixedtext="false" maxonly="false" daynight="false" eletype="H0" text="$M:$S" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext="326"/>
        <LayoutElement type="0" color="000000" x="45" y="214" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="RECUP" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="45" y="247" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="&lt;55" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="*** Zone 1***"/>
        <LayoutElement type="1" color="FFFF00" x="45" y="215" x2="83" y2="343" eletype="RV" valuetype="S1" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FFFF00" valDC00="1000" colDC00="FFFF00" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="FFFF00" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="87" y="314" fixedtext="false" maxonly="false" daynight="false" eletype="H1" text="$M:$S" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext="425"/>
        <LayoutElement type="0" color="000000" x="85" y="230" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="RESIST" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="85" y="259" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="56-75" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="***Zone 2 ***"/>
        <LayoutElement type="1" color="00FFFF" x="84" y="215" x2="121" y2="343" eletype="RV" valuetype="S2" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="00FFFF" valDC00="1000" colDC00="00FFFF" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="00FFFF" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="125" y="289" fixedtext="false" maxonly="false" daynight="false" eletype="H2" text="$M:$S" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext="528"/>
        <LayoutElement type="0" color="000000" x="123" y="214" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="TEMPO" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="123" y="247" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="76-90" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="1" color="00FF00" x="122" y="215" x2="160" y2="343" eletype="RV" valuetype="S3" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="00FF00" valDC00="1000" colDC00="00FF00" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="00FF00" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="164" y="314" fixedtext="false" maxonly="false" daynight="false" eletype="H3" text="$M:$S" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext="219"/>
        <LayoutElement type="0" color="000000" x="161" y="230" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="UMBRA" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="161" y="259" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="91-105" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="1" color="FF8080" x="161" y="215" x2="199" y2="343" eletype="RV" valuetype="S4" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF8080" valDC00="1000" colDC00="FF8080" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="FF8080" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="203" y="289" fixedtext="false" maxonly="false" daynight="false" eletype="H4" text="$M:$S" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext="126"/>
        <LayoutElement type="0" color="000000" x="200" y="214" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="VO2" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="202" y="247" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="106-120" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="1" color="FF00FF" x="200" y="215" x2="238" y2="343" eletype="RV" valuetype="S5" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF00FF" valDC00="1000" colDC00="FF00FF" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="FF00FF" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="242" y="314" fixedtext="false" maxonly="false" daynight="false" eletype="H5" text="$M:$S" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext="621"/>
        <LayoutElement type="0" color="000000" x="240" y="230" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="ANAER" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="242" y="259" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="121-150" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="*** Zone 6 ***"/>
        <LayoutElement type="1" color="8080FF" x="238" y="215" x2="276" y2="343" eletype="RV" valuetype="S6" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="8080FF" valDC00="1000" colDC00="8080FF" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="8080FF" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="280" y="289" fixedtext="false" maxonly="false" daynight="false" eletype="H6" text="$M:$S" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext="121"/>
        <LayoutElement type="0" color="000000" x="277" y="214" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="NEURO" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="277" y="247" fixedtext="true" maxonly="false" daynight="false" eletype="ND" text="&gt;150" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="Mordor"/>
        <LayoutElement type="3" text="----------------- DI2 GEAR ------------------"/>
        <LayoutElement type="0" color="000000" x="0" y="0" fixedtext="false" maxonly="false" daynight="false" eletype="U0" text="$V" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="1"/>
        <LayoutElement type="1" color="C0C1C4" x="119" y="438" x2="131" y2="468" eletype="RF" valuetype="U0" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C1C4" valDC00="20" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="10" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="1" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C1C5" x="133" y="416" x2="145" y2="468" eletype="RF" valuetype="U0" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C1C5" valDC00="30" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="20" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="10" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="0" y="0" fixedtext="false" maxonly="false" daynight="false" eletype="U3" text="$V" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="1"/>
        <LayoutElement type="1" color="C0C0C1" x="157" y="416" x2="165" y2="468" eletype="RF" valuetype="U3" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C1" valDC00="20" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="10" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="1" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C0C2" x="167" y="420" x2="175" y2="468" eletype="RF" valuetype="U3" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C2" valDC00="30" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="20" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="10" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C0C3" x="177" y="424" x2="185" y2="468" eletype="RF" valuetype="U3" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C3" valDC00="40" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="30" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="20" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C0C4" x="187" y="428" x2="195" y2="468" eletype="RF" valuetype="U3" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C4" valDC00="50" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="40" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="30" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C0C5" x="197" y="432" x2="205" y2="468" eletype="RF" valuetype="U3" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C5" valDC00="60" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="50" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="40" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C0C6" x="207" y="436" x2="215" y2="468" eletype="RF" valuetype="U3" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C6" valDC00="70" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="60" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="50" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C0C7" x="217" y="440" x2="225" y2="468" eletype="RF" valuetype="U3" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C7" valDC00="80" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="70" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="60" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C0C8" x="227" y="444" x2="235" y2="468" eletype="RF" valuetype="U3" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C8" valDC00="90" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="80" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="70" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C0C9" x="237" y="448" x2="245" y2="468" eletype="RF" valuetype="U3" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C9" valDC00="100" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="90" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="80" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C1C1" x="247" y="452" x2="255" y2="468" eletype="RF" valuetype="U3" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C1C1" valDC00="110" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="100" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="90" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C1C2" x="257" y="456" x2="265" y2="468" eletype="RF" valuetype="U3" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="123456" valDC00="120" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="110" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="100" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
    </DIYLayout>
    Hi, Could you check this layout? I have set the background of current heardrate and current power with dinamic colors but they don´t run. I don´t know what is wrong.
    thanks
  • Hi
    Your forgot the set the valuetype of the rectangle to HR / power ...
  • New version on 2.8.6 on all clones.
    2.8.6
    * fixed bug where datafield crashed when using 'display max value' and the activity was stopped and started again.
    * ANT battery value is now set to default when device is connected.
    * changed text 'INVALID' of battery and device state to '--'
    * new setting "Display max. value only" can be set for every element. For this element the maximum value is displayd/used
    instead of the average (the highest value of the average value). It is not available for low mem devices.
    It can also be used in graphic elements.
    * new value Watt per kg/pound, Watt per kg/pound NP. You will have to enter a weight in the settings!
    Watt per kg/pound NP: watt taken from normalized power, so a element with normalized power has to exist in the layout (value is taken from there)!
  • Thanks....
    Your App is so good that I'd need another clone!
    is that possible? is a nice to have for different screen configurations
  • Hi
    4 clones aren't enough? I think I dont want to make more clones, at some point Garmin must think that I want
    to flood the app store with diy datafields ;-))
  • Grinning yep, not enough if you do road, mtb and gravel and you use more than 1 screen for each!...., your fault for developing such a great app
    But first I will have to send a mail to the app store guys if this is ok. I dont want the app to get banned, because I didn't read some policy which forbids something like that...
  • Hi. I'm still tinkering with my Fenix 6 Pro Hike layout but thought it was about time I shared it....
    HM If you are looking at adding any further data values. Would you consider added a Message Notification Counter?
    Cheers HD
    <DIYLayout>
        <Device name="fenix 6 Pro / 6 Sapphire"/>
        <LayoutElement type="1" color="FFFFFF" x="130" y="130" x2="0" y2="0" eletype="CF" valuetype="FX" maxonly="false" daynight="false" radius="130" stroke="1" nr_values="1"/>
        <LayoutElement type="3" text="----- North Arrow -----"/>
        <LayoutElement type="0" color="FF0000" x="53" y="26" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="N" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="1" color="FF0000" x="76" y="30" x2="0" y2="0" eletype="DT" valuetype="SN" maxonly="false" daynight="false" radius="12" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="76" y="30" x2="0" y2="0" eletype="DT" valuetype="SN" maxonly="false" daynight="false" radius="10" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="76" y="30" x2="0" y2="0" eletype="DT" valuetype="SN" maxonly="false" daynight="false" radius="8" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="76" y="30" x2="0" y2="0" eletype="DT" valuetype="SN" maxonly="false" daynight="false" radius="6" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="76" y="30" x2="0" y2="0" eletype="DT" valuetype="SN" maxonly="false" daynight="false" radius="4" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="76" y="30" x2="0" y2="0" eletype="DT" valuetype="SN" maxonly="false" daynight="false" radius="14" stroke="2" nr_values="1"/>
        <LayoutElement type="3" text="----- Direction to Start Arrow -----"/>
        <LayoutElement type="1" color="00FF00" x="130" y="130" x2="0" y2="117" eletype="DT" valuetype="SC" maxonly="false" daynight="false" radius="12" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="00FF00" x="130" y="130" x2="0" y2="117" eletype="DT" valuetype="SC" maxonly="false" daynight="false" radius="10" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="00FF00" x="130" y="130" x2="0" y2="117" eletype="DT" valuetype="SC" maxonly="false" daynight="false" radius="8" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="00FF00" x="130" y="130" x2="0" y2="117" eletype="DT" valuetype="SC" maxonly="false" daynight="false" radius="6" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="00FF00" x="130" y="130" x2="0" y2="117" eletype="DT" valuetype="SC" maxonly="false" daynight="false" radius="4" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="130" y="130" x2="0" y2="117" eletype="DT" valuetype="SC" maxonly="false" daynight="false" radius="14" stroke="2" nr_values="1"/>
        <LayoutElement type="3" text="----- Field Seperators -----"/>
        <LayoutElement type="1" color="000000" x="68" y="34" x2="299" y2="363" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="30" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="190" y="34" x2="178" y2="244" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="30" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="72" y="226" x2="356" y2="422" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="30" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="187" y="226" x2="118" y2="183" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="30" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="33" y="45" x2="88" y2="45" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="172" y="45" x2="228" y2="45" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="97" x2="260" y2="97" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="130" x2="48" y2="130" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="212" y="130" x2="360" y2="130" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="163" x2="260" y2="163" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="33" y="217" x2="88" y2="217" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="172" y="217" x2="228" y2="217" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="3" text="----- Altitude Box -----"/>
        <LayoutElement type="1" color="000000" x="102" y="51" x2="179" y2="269" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="15" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="87" y="52" x2="87" y2="79" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="102" y="78" x2="89" y2="179" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="15" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="102" y="94" x2="158" y2="94" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="157" y="78" x2="0" y2="90" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="15" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="173" y="52" x2="173" y2="79" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="157" y="51" x2="269" y2="361" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="15" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="102" y="36" x2="157" y2="36" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="3" text="----- Timer Box -----"/>
        <LayoutElement type="1" color="000000" x="63" y="115" x2="179" y2="269" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="15" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="48" y="115" x2="48" y2="145" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="63" y="144" x2="89" y2="179" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="15" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="63" y="160" x2="197" y2="160" eletype="LN" valuetype="FX" maxonly="false" daynight="true" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="196" y="144" x2="0" y2="90" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="15" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="212" y="116" x2="212" y2="145" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="196" y="115" x2="269" y2="361" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="15" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="61" y="100" x2="196" y2="100" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="3" text="-----  Distance Box -----"/>
        <LayoutElement type="1" color="000000" x="102" y="181" x2="179" y2="269" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="15" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="87" y="182" x2="87" y2="210" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="102" y="209" x2="89" y2="179" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="15" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="102" y="225" x2="158" y2="225" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="157" y="209" x2="0" y2="90" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="15" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="173" y="181" x2="173" y2="210" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="157" y="181" x2="269" y2="361" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="15" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="102" y="166" x2="157" y2="166" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="3" text="------ Field Values -----"/>
        <LayoutElement type="0" color="000000" x="130" y="3" fixedtext="false" maxonly="false" daynight="false" eletype="CT" text="$H:$M" font="SMALL" halignment="1" precision="0" nr_values="1" sampletext="63312"/>
        <LayoutElement type="0" color="000000" x="183" y="15" fixedtext="false" maxonly="false" daynight="false" eletype="HA" text="$T" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="0"/>
        <LayoutElement type="0" color="000000" x="50" y="58" fixedtext="false" maxonly="false" daynight="false" eletype="TD" text="$V" font="LARGE" halignment="1" precision="0" nr_values="1" sampletext="457.21"/>
        <LayoutElement type="0" color="000000" x="130" y="44" fixedtext="false" maxonly="false" daynight="false" eletype="CL" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext="478.22"/>
        <LayoutElement type="0" color="000000" x="210" y="58" fixedtext="false" maxonly="false" daynight="false" eletype="TA" text="$V" font="LARGE" halignment="1" precision="0" nr_values="1" sampletext="423.66"/>
        <LayoutElement type="0" color="000000" x="23" y="111" fixedtext="false" maxonly="false" daynight="false" eletype="TV" text="$h:$M:$C" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="1200"/>
        <LayoutElement type="0" color="000000" x="23" y="144" fixedtext="false" maxonly="false" daynight="false" eletype="EV" text="$h:$M" font="XTINY" halignment="1" precision="1" nr_values="1" sampletext="56000"/>
        <LayoutElement type="0" color="000000" x="130" y="110" fixedtext="false" maxonly="false" daynight="false" eletype="TT" text="$h:$M:$S" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext="4345"/>
        <LayoutElement type="0" color="000000" x="234" y="111" fixedtext="false" maxonly="false" daynight="false" eletype="DN" text="$V" font="XTINY" halignment="1" precision="2" nr_values="1" sampletext="123"/>
        <LayoutElement type="0" color="000000" x="234" y="144" fixedtext="false" maxonly="false" daynight="false" eletype="DD" text="$V" font="XTINY" halignment="1" precision="2" nr_values="1" sampletext="456"/>
        <LayoutElement type="0" color="000000" x="55" y="179" fixedtext="false" maxonly="false" daynight="false" eletype="AS" text="$V" font="LARGE" halignment="1" precision="1" nr_values="1" sampletext="34.76"/>
        <LayoutElement type="0" color="000000" x="130" y="175" fixedtext="false" maxonly="false" daynight="false" eletype="DS" text="$V" font="NR_MILD" halignment="1" precision="1" nr_values="1" sampletext="12.56"/>
        <LayoutElement type="0" color="000000" x="205" y="179" fixedtext="false" maxonly="false" daynight="false" eletype="CS" text="$V" font="LARGE" halignment="1" precision="1" nr_values="1" sampletext="45.34"/>
        <LayoutElement type="0" color="000000" x="79" y="218" fixedtext="false" maxonly="false" daynight="false" eletype="HR" text="$V" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="A2B2C2" x="131" y="231" fixedtext="false" maxonly="false" daynight="false" eletype="BV" text="$V%" font="SMALL" halignment="1" precision="0" nr_values="2" sampletext="87"/>
        <LayoutElement type="0" color="000000" x="189" y="218" fixedtext="false" maxonly="false" daynight="false" eletype="TM" text="$V" font="TINY" halignment="0" precision="0" nr_values="1" sampletext="20"/>
        <LayoutElement type="3" text="----- Field Labels -----"/>
        <LayoutElement type="0" color="000000" x="55" y="45" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="Descent" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="130" y="37" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="Altitude" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="205" y="45" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="Ascent" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="23" y="96" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="ETE" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="23" y="129" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="ETA" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="130" y="102" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="Timer" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="234" y="96" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="Next" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="234" y="129" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="Dest" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="54" y="165" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="Avg Spd" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="130" y="167" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="Distance" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="206" y="165" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="Speed" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="1" color="000000" x="193" y="224" x2="0" y2="0" eletype="CR" valuetype="FX" maxonly="false" daynight="false" radius="2" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="200" y="219" fixedtext="true" maxonly="false" daynight="false" eletype="FX" text="C" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="----- Battery Icon -----"/>
        <LayoutElement type="1" color="000000" x="123" y="228" x2="136" y2="236" eletype="RC" valuetype="FX" maxonly="false" daynight="false" radius="4" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="60FF00" x="124" y="229" x2="131" y2="235" eletype="RF" valuetype="FX" maxonly="false" daynight="false" radius="4" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="136" y="230" x2="138" y2="234" eletype="RF" valuetype="FX" maxonly="false" daynight="false" radius="4" stroke="1" nr_values="1"/>
        <LayoutElement type="3" text="----- Heart Rate Icon -----"/>
        <LayoutElement type="1" color="FF0000" x="51" y="224" x2="0" y2="0" eletype="CF" valuetype="FX" maxonly="false" daynight="false" radius="4" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="58" y="224" x2="0" y2="0" eletype="CF" valuetype="FX" maxonly="false" daynight="false" radius="4" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="53" y="227" x2="0" y2="0" eletype="CF" valuetype="FX" maxonly="false" daynight="false" radius="4" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="56" y="227" x2="0" y2="0" eletype="CF" valuetype="FX" maxonly="false" daynight="false" radius="4" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0000" x="55" y="229" x2="0" y2="0" eletype="CF" valuetype="FX" maxonly="false" daynight="false" radius="4" stroke="1" nr_values="1"/>
        <LayoutElement type="3" text="----- Phone Connection Status Icon -----"/>
        <LayoutElement type="1" color="A1B1C1" x="63" y="105" x2="82" y2="120" eletype="RF" valuetype="PO" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="A1B1C1" x="63" y="112" x2="196" y2="120" eletype="CF" valuetype="PO" maxonly="false" daynight="false" radius="8" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="A1B1C1" x="82" y="113" x2="196" y2="120" eletype="CF" valuetype="PO" maxonly="false" daynight="false" radius="8" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="62" y="112" x2="89" y2="269" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="8" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="62" y="104" x2="82" y2="104" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="8" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="82" y="112" x2="269" y2="450" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="8" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="62" y="121" x2="82" y2="121" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="8" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="65" y="113" x2="0" y2="0" eletype="CF" valuetype="FX" maxonly="false" daynight="false" radius="4" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="79" y="113" x2="0" y2="0" eletype="CF" valuetype="FX" maxonly="false" daynight="false" radius="4" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="72" y="124" x2="232" y2="306" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="15" stroke="3" nr_values="1"/>
        <LayoutElement type="1" color="A1B1C1" x="60" y="117" x2="84" y2="117" eletype="LN" valuetype="PO" maxonly="false" daynight="false" radius="8" stroke="2" nr_values="1"/>
        <LayoutElement type="3" text="----- GPS Status Icon -----"/>
        <LayoutElement type="1" color="A0B0C0" x="178" y="105" x2="197" y2="120" eletype="RF" valuetype="GA" maxonly="false" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="A0B0C0" x="178" y="112" x2="196" y2="120" eletype="CF" valuetype="GA" maxonly="false" daynight="false" radius="8" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="A0B0C0" x="197" y="112" x2="196" y2="120" eletype="CF" valuetype="GA" maxonly="false" daynight="false" radius="8" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="177" y="112" x2="89" y2="269" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="8" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="177" y="104" x2="197" y2="104" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="8" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="197" y="112" x2="269" y2="450" eletype="AC" valuetype="FX" maxonly="false" daynight="false" radius="8" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="177" y="121" x2="197" y2="121" eletype="LN" valuetype="FX" maxonly="false" daynight="false" radius="8" stroke="2" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="187" y="102" fixedtext="true" maxonly="false" daynight="false" eletype="GA" text="GPS" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext="Mordor"/>
        <LayoutElement type="3" text="----- GPS Status Dynamic Colour -----"/>
        <LayoutElement type="2" replDC="A0B0C0" valDC00="40" colDC00="60FF00" hideDC00="false" blinkDC00="false" valDC01="20" colDC01="FFFF00" hideDC01="false" blinkDC01="false" valDC02="10" colDC02="FF0000" hideDC02="false" blinkDC02="true" invertcolor="false"/>
        <LayoutElement type="3" text="----- Phone Connection Status Dynamic Colour -----"/>
        <LayoutElement type="2" replDC="A1B1C1" valDC00="10" colDC00="0080FF" hideDC00="false" blinkDC00="false" valDC01="0" colDC01="FF0000" hideDC01="false" blinkDC01="true" invertcolor="false"/>
        <LayoutElement type="3" text="----- Battery Value Dynamic Colour -----"/>
        <LayoutElement type="2" replDC="A2B2C2" valDC00="100" colDC00="000000" hideDC00="false" blinkDC00="false" valDC01="0" colDC01="FF0000" hideDC01="false" blinkDC01="true" invertcolor="false"/>
    </DIYLayout>
