HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.9.1
* switched to new SDK 9.3.0
* added devices: Approach S72 43mm, Approach S72 47mm, D2 Mach 2 Pro, Edge 1060, Edge Explore 3, Edge Explore 3 Plus, Enduro 4, fenix 9 43mm, fenix 9 47mm, fenix 9 Pro 43mm, fenix 9 Pro 47mm, fenix 9 Pro 51mm,
fenix 9 Pro Solar 47mm, fenix 9 Pro Solar 51mm, Forerunner 70, Forerunner 170, Forerunner 170 Music, MARQ (Gen 3)
3.8.3
* fixed problem with backslash in configuration string
3.8.1
* switched to new SDK 8.3.0
* added devices: Approach S50, D2 Mach 2, Descent G2, Edge 550, Edge 850, Edge MTB, eTrex Touch, fēnix 8 Pro 47mm / 51mm / MicroLED, Forerunner 970, Forerunner 570 42mm, Forerunner 570 47mm,
GPSMAP H1, Instinct 3 AMOLED 45mm, Instinct 3 AMOLED 50mm, Instinct 3 Solar 45mm / 50mm, Instinct Crossover AMOLED, Instinct E 40mm, Instinct E 45mm, Venu 4 41mm, Venu 4 45mm / D2 Air X15, Venu X1, vívoactive 6
for full releasenotes see: releasenotes.txt
  • <?xml version="1.0" encoding="UTF-8"?>
    <DIYLayout>
        <Device name="Edge 1030"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="0" x2="282" y2="470" eletype="RF" valuetype="FX" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="3" text="-----------------DATAFIELD LINES ------------------"/>
        <LayoutElement type="1" color="000000" x="0" y="48" x2="282" y2="48" eletype="LN" valuetype="FX" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="118" x2="282" y2="118" eletype="LN" valuetype="FX" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="176" x2="282" y2="176" eletype="LN" valuetype="FX" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="2" y="301" x2="280" y2="301" eletype="LN" valuetype="FX" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="141" y="415" x2="141" y2="415" eletype="LN" valuetype="FX" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="141" y="118" x2="141" y2="176" eletype="LN" valuetype="FX" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="3" text="-----------------DATA FIELS IN UPPER REGION ------------------"/>
        <LayoutElement type="3" text="*** Battery ***"/>
        <LayoutElement type="1" color="000000" x="10" y="6" x2="46" y2="23" eletype="RF" valuetype="FX" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="45" y="10" x2="51" y2="19" eletype="RF" valuetype="FX" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="12" y="8" x2="45" y2="21" eletype="RF" valuetype="BV" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF0001" x="13" y="15" x2="19" y2="21" eletype="RF" valuetype="BV" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="00B001" x="12" y="8" x2="46" y2="21" eletype="RH" valuetype="BV" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="00B001" valDC00="980" colDC00="008000" hideDC00="false" blinkDC00="false" valDC01="750" colDC01="80FF00" hideDC01="false" blinkDC01="false" valDC02="500" colDC02="FF8000" hideDC02="false" blinkDC02="false" valDC03="250" colDC03="FFFF00" hideDC03="false" blinkDC03="false" valDC04="100" colDC04="FF0000" hideDC04="false" blinkDC04="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="53" y="23" fixedtext="false" daynight="true" eletype="BV" text="$V %" font="TINY" halignment="0" precision="0" nr_values="1" sampletext="87"/>
        <LayoutElement type="3" text="*** Time ***"/>
        <LayoutElement type="0" color="000000" x="141" y="0" fixedtext="false" daynight="true" eletype="CT" text="$H:$M" font="TINY" halignment="1" precision="0" nr_values="1" sampletext="63312"/>
        <LayoutElement type="3" text="*** Altitude ***"/>
        <LayoutElement type="0" color="000000" x="141" y="30" fixedtext="false" daynight="true" eletype="CL" text=" Altitud  $V m" font="XTINY" halignment="1" precision="1" nr_values="1" sampletext="1478.22"/>
        <LayoutElement type="3" text="*** GPS ***"/>
        <LayoutElement type="0" color="000000" x="232" y="0" fixedtext="true" daynight="true" eletype="FX" text="GPS" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="1" color="000000" x="262" y="12" x2="0" y2="0" eletype="CR" valuetype="FX" daynight="true" radius="10" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FF000E" x="262" y="12" x2="0" y2="0" eletype="CF" valuetype="GA" daynight="false" radius="9" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="FF000E" valDC00="40" colDC00="00A800" hideDC00="false" blinkDC00="false" valDC01="30" colDC01="00FC00" hideDC01="false" blinkDC01="false" valDC02="20" colDC02="F8C840" hideDC02="false" blinkDC02="false" valDC03="10" colDC03="F80000" hideDC03="false" blinkDC03="false" valDC04="1" colDC04="FFFFFF" hideDC04="false" blinkDC04="false" invertcolor="false"/>
        <LayoutElement type="3" text="*** Temperature ***"/>
        <LayoutElement type="0" color="000000" x="244" y="24" fixedtext="false" daynight="true" eletype="TM" text="$V ºC" font="TINY" halignment="1" precision="1" nr_values="1" sampletext="20.5"/>
        <LayoutElement type="3" text="----------------- SECOND LINE ------------------"/>
        <LayoutElement type="3" text="*** Speed ***"/>
        <LayoutElement type="1" color="E2E2E0" x="29" y="80" x2="0" y2="0" eletype="CR" valuetype="CS" daynight="false" radius="17" stroke="3" nr_values="1"/>
        <LayoutElement type="1" color="E2E2E0" x="31" y="78" x2="39" y2="70" eletype="LN" valuetype="CS" daynight="false" radius="0" stroke="3" nr_values="1"/>
        <LayoutElement type="1" color="E2E2E0" x="30" y="79" x2="0" y2="0" eletype="CR" valuetype="CS" daynight="false" radius="2" stroke="3" nr_values="1"/>
        <LayoutElement type="1" color="E2E2E0" x="14" y="84" x2="45" y2="84" eletype="LN" valuetype="CS" daynight="false" radius="0" stroke="3" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="14" y="88" x2="45" y2="101" eletype="RF" valuetype="FX" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="0000FF" x="138" y="47" fixedtext="false" daynight="true" eletype="CS" text="$V" font="NR_HOT" halignment="0" precision="1" nr_values="1" sampletext="45.34"/>
        <LayoutElement type="0" color="000000" x="79" y="98" fixedtext="true" daynight="true" eletype="AS" text="Avg." font="XTINY" halignment="1" precision="1" nr_values="1" sampletext="34.76"/>
        <LayoutElement type="0" color="0000FF" x="131" y="94" fixedtext="false" daynight="true" eletype="AS" text="$V" font="TINY" halignment="0" precision="1" nr_values="1" sampletext="45.34"/>
        <LayoutElement type="0" color="000000" x="47" y="91" fixedtext="true" daynight="true" eletype="AS" text="Km/h" font="XTINY" halignment="0" precision="1" nr_values="1" sampletext="34.76"/>
        <LayoutElement type="3" text="*** Cadence ***"/>
        <LayoutElement type="1" color="E1E1E1" x="180" y="79" x2="0" y2="0" eletype="CF" valuetype="CC" daynight="false" radius="14" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="E1E1E1" x="193" y="95" x2="165" y2="62" eletype="LN" valuetype="CC" daynight="false" radius="0" stroke="3" nr_values="1"/>
        <LayoutElement type="1" color="800080" x="180" y="80" x2="0" y2="0" eletype="CR" valuetype="CC" daynight="false" radius="2" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="E1E1E1" x="158" y="63" x2="166" y2="63" eletype="LN" valuetype="CC" daynight="false" radius="0" stroke="3" nr_values="1"/>
        <LayoutElement type="1" color="E1E1E1" x="194" y="95" x2="202" y2="95" eletype="LN" valuetype="CC" daynight="false" radius="0" stroke="3" nr_values="1"/>
        <LayoutElement type="0" color="008000" x="274" y="47" fixedtext="false" daynight="true" eletype="CC" text="$V" font="NR_HOT" halignment="0" precision="0" nr_values="1" sampletext="167.34"/>
        <LayoutElement type="0" color="000000" x="220" y="98" fixedtext="true" daynight="true" eletype="AS" text="Avg." font="XTINY" halignment="1" precision="1" nr_values="1" sampletext="34.76"/>
        <LayoutElement type="0" color="008000" x="264" y="94" fixedtext="false" daynight="true" eletype="AC" text="$V" font="TINY" halignment="0" precision="0" nr_values="1" sampletext="188.45"/>
        <LayoutElement type="3" text="----------------- TIME + DISTANCE ------------------"/>
        <LayoutElement type="0" color="000000" x="5" y="121" fixedtext="true" daynight="true" eletype="FX" text="Tiempo" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="70" y="137" fixedtext="false" daynight="true" eletype="TT" text="$H:$M:$S" font="NR_MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="4374"/>
        <LayoutElement type="0" color="000000" x="147" y="121" fixedtext="true" daynight="true" eletype="FX" text="Distancia" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="243" y="137" fixedtext="false" daynight="true" eletype="DS" text="$V" font="NR_MEDIUM" halignment="0" precision="2" nr_values="1" sampletext="121.21"/>
        <LayoutElement type="0" color="000000" x="253" y="147" fixedtext="true" daynight="true" eletype="FX" text="Km" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="-----------------WATTS ZONE ------------------"/>
        <LayoutElement type="3" text="*** Power picture ***"/>
        <LayoutElement type="1" color="0F4FFF" x="15" y="192" x2="26" y2="201" eletype="LN" valuetype="FX" daynight="true" radius="0" stroke="7" nr_values="1"/>
        <LayoutElement type="1" color="0F4FFF" x="6" y="203" x2="17" y2="212" eletype="LN" valuetype="FX" daynight="true" radius="0" stroke="7" nr_values="1"/>
        <LayoutElement type="1" color="0F4FFF" x="18" y="198" x2="13" y2="205" eletype="LN" valuetype="FX" daynight="true" radius="0" stroke="5" nr_values="1"/>
        <LayoutElement type="3" text="*** Current Power ***"/>
        <LayoutElement type="1" color="000000" x="32" y="185" x2="99" y2="222" eletype="RC" valuetype="FX" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFF1" x="34" y="187" x2="98" y2="221" eletype="RF" valuetype="CB" daynight="false" radius="0" stroke="3" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="29" y="185" fixedtext="false" daynight="false" eletype="CB" text="$V" font="NR_MEDIUM" halignment="2" precision="0" nr_values="1" sampletext="455.34"/>
        <LayoutElement type="2" replDC="FFFFF1" valDC00="2310" colDC00="8000FF" hideDC00="false" blinkDC00="false" valDC01="1850" colDC01="FF0000" hideDC01="false" blinkDC01="false" valDC02="1620" colDC02="E2992C" hideDC02="false" blinkDC02="false" valDC03="1390" colDC03="E8C917" hideDC03="false" blinkDC03="false" valDC04="1160" colDC04="008000" hideDC04="false" blinkDC04="false" valDC05="850" colDC05="00FFFF" hideDC05="false" blinkDC05="false" valDC06="390" colDC06="C0C0C0" hideDC06="false" blinkDC06="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="76" y="196" fixedtext="true" daynight="false" eletype="FX" text="w" font="TINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="*** TSS ***"/>
        <LayoutElement type="1" color="000000" x="117" y="186" x2="187" y2="218" eletype="RC" valuetype="FX" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="118" y="191" fixedtext="true" daynight="true" eletype="FX" text="TSS" font="TINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="147" y="190" fixedtext="false" daynight="true" eletype="TS" text="$V" font="SMALL" halignment="2" precision="0" nr_values="1" sampletext="178.13"/>
        <LayoutElement type="3" text="*** N.P. ***"/>
        <LayoutElement type="0" color="FFFFFF" x="1" y="1" fixedtext="false" daynight="false" eletype="NB" text="$V" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="425.34"/>
        <LayoutElement type="3" text="*** FTP ***"/>
        <LayoutElement type="1" color="000000" x="197" y="186" x2="273" y2="218" eletype="RC" valuetype="FX" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="230" y="191" fixedtext="true" daynight="true" eletype="FX" text="FTP" font="TINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="229" y="189" fixedtext="false" daynight="true" eletype="FT" text="$V%" font="SMALL" halignment="2" precision="0" nr_values="1" sampletext="78.13"/>
        <LayoutElement type="3" text="*** Zone 0 ***"/>
        <LayoutElement type="1" color="C0C0C0" x="1" y="235" x2="41" y2="302" eletype="RV" valuetype="S0" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="34" y="280" fixedtext="false" daynight="false" eletype="S0" text="$V %" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="15"/>
        <LayoutElement type="0" color="000000" x="36" y="235" fixedtext="false" daynight="false" eletype="H1" text="$M:$S" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="425"/>
        <LayoutElement type="2" replDC="C0C0C0" valDC00="1000" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="C0C0C0" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="3" text="*** Zone 1***"/>
        <LayoutElement type="1" color="0080C0" x="41" y="235" x2="81" y2="302" eletype="RV" valuetype="S1" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="74" y="280" fixedtext="false" daynight="false" eletype="S1" text="$V %" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="20"/>
        <LayoutElement type="0" color="000000" x="77" y="235" fixedtext="false" daynight="false" eletype="H1" text="$M:$S" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="425"/>
        <LayoutElement type="2" replDC="0080C0" valDC00="1000" colDC00="0080C0" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="0080C0" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="3" text="***Zone 2 ***"/>
        <LayoutElement type="1" color="00FF80" x="81" y="235" x2="121" y2="302" eletype="RV" valuetype="S2" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="115" y="280" fixedtext="false" daynight="false" eletype="S2" text="$V %" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="30"/>
        <LayoutElement type="0" color="000000" x="116" y="235" fixedtext="false" daynight="false" eletype="H2" text="$M:$S" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="528"/>
        <LayoutElement type="2" replDC="00FF80" valDC00="1000" colDC00="00FF80" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="00FF80" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="3" text="*** Zone 3 ***"/>
        <LayoutElement type="1" color="FCF71F" x="121" y="235" x2="161" y2="302" eletype="RV" valuetype="S3" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="155" y="280" fixedtext="false" daynight="false" eletype="S3" text="$V %" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="40"/>
        <LayoutElement type="0" color="000000" x="155" y="235" fixedtext="false" daynight="false" eletype="H3" text="$M:$S" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="219"/>
        <LayoutElement type="2" replDC="FCF71F" valDC00="1000" colDC00="FCF71F" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="FCF71F" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="3" text="*** Zone 4 ***"/>
        <LayoutElement type="1" color="F56C07" x="161" y="235" x2="201" y2="302" eletype="RV" valuetype="S4" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="193" y="280" fixedtext="false" daynight="false" eletype="S4" text="$V %" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="50"/>
        <LayoutElement type="0" color="000000" x="195" y="235" fixedtext="false" daynight="false" eletype="H4" text="$M:$S" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="126"/>
        <LayoutElement type="2" replDC="F56C07" valDC00="1000" colDC00="F56C07" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="F56C07" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="3" text="*** Zone 5 ***"/>
        <LayoutElement type="1" color="FF0000" x="201" y="235" x2="241" y2="302" eletype="RV" valuetype="S5" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="233" y="280" fixedtext="false" daynight="false" eletype="P4" text="$V %" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="60"/>
        <LayoutElement type="0" color="000000" x="234" y="235" fixedtext="false" daynight="false" eletype="H5" text="$M:$S" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="621"/>
        <LayoutElement type="2" replDC="FF0000" valDC00="1000" colDC00="FF0000" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="FF0000" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="3" text="*** Zone 6 ***"/>
        <LayoutElement type="1" color="8000FF" x="241" y="235" x2="281" y2="302" eletype="RV" valuetype="S6" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="274" y="280" fixedtext="false" daynight="false" eletype="S6" text="$V %" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="70"/>
        <LayoutElement type="0" color="000000" x="275" y="235" fixedtext="false" daynight="false" eletype="H6" text="$M:$S" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="121"/>
        <LayoutElement type="2" replDC="8000FF" valDC00="1000" colDC00="8000FF" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="8000FF" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="3" text="----------------- KCAL  ------------------"/>
        <LayoutElement type="0" color="000000" x="51" y="305" fixedtext="false" daynight="true" eletype="CA" text="$V" font="TINY" halignment="0" precision="0" nr_values="1" sampletext="1563.77"/>
        <LayoutElement type="0" color="000000" x="75" y="309" fixedtext="true" daynight="true" eletype="FX" text="Cal." font="XTINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="----------------- TRAINING EFFECT (T.E.)  ------------------"/>
        <LayoutElement type="1" color="000000" x="187" y="308" x2="268" y2="334" eletype="RC" valuetype="FX" daynight="true" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="FFFFF9" x="187" y="308" x2="268" y2="334" eletype="RF" valuetype="TE" daynight="false" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="226" y="308" fixedtext="true" daynight="false" eletype="FX" text="T.E." font="SMALL" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="228" y="308" fixedtext="false" daynight="false" eletype="TE" text="$V" font="SMALL" halignment="2" precision="1" nr_values="1" sampletext="4.2"/>
        <LayoutElement type="2" replDC="FFFFF9" valDC00="50" colDC00="FF0000" hideDC00="false" blinkDC00="false" valDC01="40" colDC01="FF8000" hideDC01="false" blinkDC01="false" valDC02="30" colDC02="80FF00" hideDC02="false" blinkDC02="false" valDC03="20" colDC03="00FFFF" hideDC03="false" blinkDC03="false" valDC04="10" colDC04="C0C0C0" hideDC04="false" blinkDC04="false" invertcolor="false"/>
        <LayoutElement type="3" text="----------------- HEARTRATE ZONE ------------------"/>
        <LayoutElement type="3" text="*** Heartrate Picture ***"/>
        <LayoutElement type="1" color="F80000" x="35" y="346" x2="0" y2="0" eletype="CF" valuetype="FX" daynight="false" radius="7" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="F80000" x="46" y="346" x2="0" y2="0" eletype="CF" valuetype="FX" daynight="false" radius="7" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="F80000" x="41" y="353" x2="0" y2="0" eletype="CF" valuetype="FX" daynight="false" radius="6" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="F80000" x="30" y="349" x2="42" y2="360" eletype="LN" valuetype="FX" daynight="false" radius="6" stroke="3" nr_values="1"/>
        <LayoutElement type="1" color="F80000" x="51" y="349" x2="41" y2="360" eletype="LN" valuetype="FX" daynight="false" radius="5" stroke="3" nr_values="1"/>
        <LayoutElement type="3" text="*** Current Heartrate ***"/>
        <LayoutElement type="1" color="000000" x="4" y="336" x2="77" y2="406" eletype="RC" valuetype="FX" daynight="true" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="8" y="365" x2="73" y2="402" eletype="RC" valuetype="FX" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFF3" x="10" y="367" x2="72" y2="401" eletype="RF" valuetype="HR" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="67" y="365" fixedtext="false" daynight="false" eletype="HR" text="$V" font="NR_MEDIUM" halignment="0" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="2" replDC="FFFFF3" valDC00="1740" colDC00="FF0000" hideDC00="false" blinkDC00="false" valDC01="1570" colDC01="FF8000" hideDC01="false" blinkDC01="false" valDC02="1390" colDC02="80FF00" hideDC02="false" blinkDC02="false" valDC03="1220" colDC03="00FFFF" hideDC03="false" blinkDC03="false" valDC04="1040" colDC04="808080" hideDC04="false" blinkDC04="false" invertcolor="false"/>
        <LayoutElement type="3" text="*** Zone 1 ***"/>
        <LayoutElement type="1" color="808080" x="81" y="338" x2="121" y2="408" eletype="RV" valuetype="P1" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="115" y="387" fixedtext="false" daynight="false" eletype="P1" text="$V %" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="25"/>
        <LayoutElement type="0" color="000000" x="116" y="339" fixedtext="false" daynight="false" eletype="T1" text="$M:$S" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="425"/>
        <LayoutElement type="2" replDC="808080" valDC00="1000" colDC00="808080" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="808080" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="3" text="*** Zone 2 ***"/>
        <LayoutElement type="1" color="0080FF" x="121" y="338" x2="161" y2="408" eletype="RV" valuetype="P2" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="152" y="387" fixedtext="false" daynight="false" eletype="P2" text="$V %" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="10"/>
        <LayoutElement type="0" color="000000" x="156" y="339" fixedtext="false" daynight="false" eletype="T2" text="$M:$S" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="528"/>
        <LayoutElement type="2" replDC="0080FF" valDC00="1000" colDC00="0080FF" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="0080FF" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="1" color="80FF00" x="161" y="338" x2="201" y2="408" eletype="RV" valuetype="P3" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="194" y="387" fixedtext="false" daynight="false" eletype="P3" text="$V %" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="18"/>
        <LayoutElement type="0" color="000000" x="196" y="339" fixedtext="false" daynight="false" eletype="T3" text="$M:$S" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="219"/>
        <LayoutElement type="2" replDC="80FF00" valDC00="1000" colDC00="80FF00" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="80FF00" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="1" color="FF8000" x="201" y="338" x2="241" y2="408" eletype="RV" valuetype="P4" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="233" y="387" fixedtext="false" daynight="false" eletype="P4" text="$V %" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="13"/>
        <LayoutElement type="0" color="000000" x="235" y="339" fixedtext="false" daynight="false" eletype="T4" text="$M:$S" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="126"/>
        <LayoutElement type="2" replDC="FF8000" valDC00="1000" colDC00="FF8000" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="FF8000" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="1" color="FF0005" x="241" y="338" x2="281" y2="408" eletype="RV" valuetype="P5" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="274" y="387" fixedtext="false" daynight="false" eletype="P5" text="$V %" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="19"/>
        <LayoutElement type="0" color="000000" x="276" y="339" fixedtext="false" daynight="false" eletype="T5" text="$M:$S" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="621"/>
        <LayoutElement type="2" replDC="FF0005" valDC00="1000" colDC00="FF0000" hideDC00="false" blinkDC00="false" valDC01="1" colDC01="FF0000" hideDC01="false" blinkDC01="false" invertcolor="false"/>
        <LayoutElement type="3" text="----------------- GRADIENT ------------------"/>
        <LayoutElement type="0" color="000000" x="3" y="420" fixedtext="true" daynight="true" eletype="ND" text="Pendiente" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext="Mordor"/>
        <LayoutElement type="0" color="000000" x="50" y="436" fixedtext="false" daynight="true" eletype="GR" text="$V" font="MEDIUM" halignment="0" precision="1" nr_values="1" sampletext="16.69"/>
        <LayoutElement type="0" color="000000" x="69" y="436" fixedtext="true" daynight="true" eletype="FX" text="%" font="MEDIUM" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="3" text="----------------- Total ascent ------------------"/>
        <LayoutElement type="0" color="000000" x="117" y="411" fixedtext="false" daynight="true" eletype="TA" text="$V" font="TINY" halignment="0" precision="1" nr_values="1" sampletext="423.66"/>
        <LayoutElement type="1" color="000000" x="92" y="437" x2="89" y2="443" eletype="LN" valuetype="FX" daynight="true" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="92" y="437" x2="95" y2="443" eletype="LN" valuetype="FX" daynight="true" radius="0" stroke="2" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="92" y="437" x2="92" y2="453" eletype="LN" valuetype="FX" daynight="true" radius="0" stroke="3" nr_values="1"/>
        <LayoutElement type="3" text="----------------- Di2 GEARS ------------------"/>
        <LayoutElement type="0" color="000000" x="0" y="0" fixedtext="false" daynight="false" eletype="U0" text="$V" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="1"/>
        <LayoutElement type="1" color="C0C1C4" x="119" y="443" x2="131" y2="468" eletype="RF" valuetype="U0" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C1C4" valDC00="20" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="10" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="1" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C1C5" x="133" y="421" x2="145" y2="468" eletype="RF" valuetype="U0" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C1C5" valDC00="30" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="20" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="10" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="0" color="000000" x="272" y="422" fixedtext="false" daynight="true" eletype="U3" text="$V/11" font="TINY" halignment="0" precision="0" nr_values="1" sampletext="10"/>
        <LayoutElement type="1" color="C0C0C1" x="157" y="421" x2="165" y2="468" eletype="RF" valuetype="U3" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C1" valDC00="20" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="10" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="1" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C0C2" x="167" y="425" x2="175" y2="468" eletype="RF" valuetype="U3" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C2" valDC00="30" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="20" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="10" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C0C3" x="177" y="429" x2="185" y2="468" eletype="RF" valuetype="U3" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C3" valDC00="40" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="30" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="20" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C0C4" x="187" y="433" x2="195" y2="468" eletype="RF" valuetype="U3" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C4" valDC00="50" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="40" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="30" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C0C5" x="197" y="437" x2="205" y2="468" eletype="RF" valuetype="U3" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C5" valDC00="60" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="50" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="40" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C0C6" x="207" y="441" x2="215" y2="468" eletype="RF" valuetype="U3" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C6" valDC00="70" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="60" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="50" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C0C7" x="217" y="445" x2="225" y2="468" eletype="RF" valuetype="U3" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C7" valDC00="80" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="70" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="60" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C0C8" x="227" y="449" x2="235" y2="468" eletype="RF" valuetype="U3" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C8" valDC00="90" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="80" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="70" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C0C9" x="237" y="453" x2="245" y2="468" eletype="RF" valuetype="U3" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C0C9" valDC00="100" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="90" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="80" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C1C1" x="247" y="457" x2="255" y2="468" eletype="RF" valuetype="U3" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C1C1" valDC00="110" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="100" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="90" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
        <LayoutElement type="1" color="C0C1C2" x="257" y="461" x2="265" y2="468" eletype="RF" valuetype="U3" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="2" replDC="C0C1C2" valDC00="120" colDC00="C0C0C0" hideDC00="false" blinkDC00="false" valDC01="110" colDC01="0000FF" hideDC01="false" blinkDC01="false" valDC02="100" colDC02="C0C0C0" hideDC02="false" blinkDC02="false" invertcolor="false"/>
    </DIYLayout>
  • There is no "Speed" text in your design - so you're still unclear / diffuse in your question...  Thinking
    But in principle (as already said): the NR_-fonts are made to display digits, not text.
    They can be used to display text (at least for Edge 1030 device, don't know about others) - but that text is always UPPERCASE... (and it's not guaranteed, that they display text).
    So to summarize: don't use NR_-Fonts to display text, only use the other ones (XTINY, TINY, SMALL, MEDIUM, LARGE).
    If you need to display text (e.g. as pre- or postfix) together with a value either use a text font for that field or use two fields, one with the numerical value and another one with the text.
  • Ok, there is no "Speed" but he has changed to Italian(?).
    Look at TIEMPO and DISTANCIA, which is declared as XTINY.
    He's really got a problem with his designer program which apparently does not what it should do on his PC.
    (I have minor problems, too: my old WIN7 PC cannot show DEJAVU font which is built in in the designer.)
    On his preview even the rectangles are shown in wrong color and wrong stroke.
    On my old WIN7 PC the submitted code above looks like this:
    Edit: the rectangles on my small resolution picture also looks wrong! It seems it is about fonts only!
  • I will look at it again. It is with W10.
    I have the problem with "ALTITUD" (Altitud), "DISTANCIA" (Distancia), etc.  Is spanish.      But Bodenseematze has said that it is for using NR_-Fonts. Solved.
    Now I want to look at the rectangles. I want only the frame to change color with the HR and Power values.
    I started two weeks ago and am still learning to design.
    Thank you.
  • What I don‘t get is: there are no NR_Fonts that little available.
    But if it is solved - all is well!
  • Just another idea... to make things clearer:
    Use the code below - don't make any changes - and look what it is like in your designer.
    It shold look like this:
    (if not - please submit a screenshot)
    <DIYLayout>
        <LayoutElement type="1" color="FFFFFF" x="0" y="0" x2="282" y2="470" eletype="RF" valuetype="FX" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="78" x2="282" y2="78" eletype="LN" valuetype="FX" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="156" x2="282" y2="156" eletype="LN" valuetype="FX" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="235" x2="282" y2="235" eletype="LN" valuetype="FX" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="313" x2="282" y2="313" eletype="LN" valuetype="FX" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="0" y="392" x2="282" y2="392" eletype="LN" valuetype="FX" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="000000" x="141" y="0" x2="141" y2="470" eletype="LN" valuetype="FX" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="000000" x="1" y="1" fixedtext="true" daynight="false" eletype="FX" text="Xtiny" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="142" y="1" fixedtext="true" daynight="false" eletype="FX" text="Tiny" font="TINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="1" y="79" fixedtext="true" daynight="false" eletype="FX" text="Small" font="SMALL" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="142" y="79" fixedtext="true" daynight="false" eletype="FX" text="Medium" font="MEDIUM" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="1" y="157" fixedtext="true" daynight="false" eletype="FX" text="Large" font="LARGE" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="1" y="236" fixedtext="true" daynight="false" eletype="FX" text="NR_MILD" font="NR_MILD" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="1" y="314" fixedtext="true" daynight="false" eletype="FX" text="NR_MED" font="NR_MEDIUM" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="1" y="393" fixedtext="true" daynight="false" eletype="FX" text="NR_HO" font="NR_HOT" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="70" y="119" fixedtext="false" daynight="false" eletype="HR" text="$V" font="SMALL" halignment="1" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="000000" x="211" y="118" fixedtext="false" daynight="false" eletype="HR" text="$V" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="000000" x="211" y="170" fixedtext="false" daynight="false" eletype="HR" text="$V" font="LARGE" halignment="1" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="000000" x="211" y="256" fixedtext="false" daynight="false" eletype="HR" text="$V" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="000000" x="211" y="333" fixedtext="false" daynight="false" eletype="HR" text="$V" font="NR_MEDIUM" halignment="1" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="000000" x="211" y="407" fixedtext="false" daynight="false" eletype="HR" text="$V" font="NR_HOT" halignment="1" precision="0" nr_values="1" sampletext="183.55"/>
    </DIYLayout>
  • I made small changes to your test design - I positioned all texts and numbers one pixel beyond / left / right their lines.
    So all numbers and texts should be positioned directly at the lines or am I wrong?
    In my designer it looks like this:
    Especially the text and number for the "Large" font is IMHO not correctly positioned - the one for NR_HOT also not, but that is only a few pixels off...
    I use Windows 10 Pro, German (Build 18362, 19h1_release.190318-1202); scaling factor is at 100% (= no scaling)
    Here's the changed code:
    <DIYLayout>
        <LayoutElement type="0" color="000000" x="1" y="0" fixedtext="true" daynight="false" eletype="FX" text="XTiny" font="XTINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="280" y="0" fixedtext="true" daynight="false" eletype="FX" text="Tiny" font="TINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="280" y="79" fixedtext="true" daynight="false" eletype="FX" text="Medium" font="MEDIUM" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="000000" x="140" y="0" fixedtext="false" daynight="false" eletype="HR" text="$V" font="XTINY" halignment="0" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="000000" x="142" y="0" fixedtext="false" daynight="false" eletype="HR" text="$V" font="TINY" halignment="2" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="000000" x="140" y="79" fixedtext="false" daynight="false" eletype="HR" text="$V" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="000000" x="142" y="79" fixedtext="false" daynight="false" eletype="HR" text="$V" font="MEDIUM" halignment="2" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="000000" x="142" y="157" fixedtext="false" daynight="false" eletype="HR" text="$V" font="LARGE" halignment="2" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="000000" x="142" y="236" fixedtext="false" daynight="false" eletype="HR" text="$V" font="NR_MILD" halignment="2" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="000000" x="142" y="314" fixedtext="false" daynight="false" eletype="HR" text="$V" font="NR_MEDIUM" halignment="2" precision="0" nr_values="1" sampletext="183.55"/>
        <LayoutElement type="0" color="000000" x="142" y="393" fixedtext="false" daynight="false" eletype="HR" text="$V" font="NR_HOT" halignment="2" precision="0" nr_values="1" sampletext="183.55"/>
    </DIYLayout>
  • New version 2.8.4 on #4.
    http://public.stattegg.info/HM_DIYD_2.8.4.zip
    Please test ant battery status with a low battery, if the status is changed correctly.
    2.8.4
    * new setting "Display max. value only" can be set for every element. For this element the maximum value is displayd/used
    instead of the average (the highest value of the average value). It is not available for low mem devices.
    It can also be used in graphic elements.
    * new value Watt per kg/pound, Watt per kg/pound NP. You will have to enter a weight in the settings!
    Watt per kg/pound NP: watt taken from normalized power, so a element with normalized power has to exist in the layout (value is taken from there)!
    * changed ANT battery status default value to OK. It seems that only battery stati other than OK are sent.
  • Some more little changes: version 2.8.5 (datafield only!)
    2.8.5 (datafield only)
    * ANT battery value is now set to default when device is connected.
    * changed text 'INVALID' of battery and device state to '--'
  • Have you checked what I told you about the size of the screen? Now is shorter and only appear 5 fields of dinamic colors.
