HMs DIY #1-6
Store Link
Because I want to keep this datafield and the app free for use I would be very grateful about a small donation to PayPal
A detailed description of how to use it can be found here:
HMs_DIY_GUIDANCE.pdf
HMs_DIY_ANLEITUNG.pdf
Thanks very much to mcinner1 for putting so much time into this documentation!
Designer download
You can contribute on my github page.
You can upload your layout so others can use it as well.
Also any changes to the fonts.txt can be updated there as well.
Garmin_HMsDIY
RELEASE NOTES
3.9.1
* switched to new SDK 9.3.0
* added devices: Approach S72 43mm, Approach S72 47mm, D2 Mach 2 Pro, Edge 1060, Edge Explore 3, Edge Explore 3 Plus, Enduro 4, fenix 9 43mm, fenix 9 47mm, fenix 9 Pro 43mm, fenix 9 Pro 47mm, fenix 9 Pro 51mm,
fenix 9 Pro Solar 47mm, fenix 9 Pro Solar 51mm, Forerunner 70, Forerunner 170, Forerunner 170 Music, MARQ (Gen 3)
3.8.3
* fixed problem with backslash in configuration string
3.8.1
* switched to new SDK 8.3.0
* added devices: Approach S50, D2 Mach 2, Descent G2, Edge 550, Edge 850, Edge MTB, eTrex Touch, fēnix 8 Pro 47mm / 51mm / MicroLED, Forerunner 970, Forerunner 570 42mm, Forerunner 570 47mm,
GPSMAP H1, Instinct 3 AMOLED 45mm, Instinct 3 AMOLED 50mm, Instinct 3 Solar 45mm / 50mm, Instinct Crossover AMOLED, Instinct E 40mm, Instinct E 45mm, Venu 4 41mm, Venu 4 45mm / D2 Air X15, Venu X1, vívoactive 6
for full releasenotes see: releasenotes.txt
    Former Member in reply to mcinner1
    Layout, as XML:
    <?xml version="1.0" encoding="UTF-8"?>
    <DIYLayout>
        <Device name="fenix 6X Pro / 6X Sapphire / 6X Pro Solar"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="22" x2="280" y2="22" eletype="LN" valuetype="FX" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="62" x2="280" y2="62" eletype="LN" valuetype="FX" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="99" x2="280" y2="99" eletype="LN" valuetype="FX" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="151" x2="280" y2="151" eletype="LN" valuetype="FX" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="0" y="210" x2="280" y2="210" eletype="LN" valuetype="FX" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="139" y="0" x2="139" y2="280" eletype="LN" valuetype="FX" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="40" y="0" x2="40" y2="240" eletype="LN" valuetype="FX" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="240" y="0" x2="240" y2="240" eletype="LN" valuetype="FX" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="139" y="8" fixedtext="true" daynight="false" eletype="FX" text="00" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="40" y="35" fixedtext="true" daynight="false" eletype="FX" text="00" font="TINY" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="139" y="35" fixedtext="true" daynight="false" eletype="FX" text="00" font="TINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="240" y="35" fixedtext="true" daynight="false" eletype="FX" text="00" font="TINY" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="40" y="62" fixedtext="true" daynight="false" eletype="FX" text="00" font="SMALL" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="139" y="62" fixedtext="true" daynight="false" eletype="FX" text="00" font="SMALL" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="240" y="62" fixedtext="true" daynight="false" eletype="FX" text="00" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="40" y="99" fixedtext="true" daynight="false" eletype="FX" text="00" font="MEDIUM" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="139" y="99" fixedtext="true" daynight="false" eletype="FX" text="00" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="240" y="99" fixedtext="true" daynight="false" eletype="FX" text="00" font="MEDIUM" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="40" y="151" fixedtext="true" daynight="false" eletype="FX" text="00" font="LARGE" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="139" y="151" fixedtext="true" daynight="false" eletype="FX" text="8" font="LARGE" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="240" y="151" fixedtext="true" daynight="false" eletype="FX" text="00" font="LARGE" halignment="0" precision="0" nr_values="1" sampletext=""/>
    </DIYLayout>
    fonts.txt.zip
  • Hi
    After a quick look: You have to load the layout in the designer, copy the config string to your watch and from there adapt the preview in the designer so it matches your watch! Not the other way around! The fonts in the watch are fixed, you have to adapt the preview in the designer.
    I will try it in the simulator and post the fonts.txt here.
    regards
    Erich
  • you have to adapt the preview in the designer.
    YESS!
    I did for you a new fonts.txt (attached as zip) and 3 layouts.
    Please upload the 3 layouts to your watch using the downloaded fonts-file and make a foto (better a screenshot) of each layout - how it looks on the watch.
    fontsNEW.zip
    Code for the first picture:
    <DIYLayout>
        <LayoutElement type="1" color="FFFFFF" x="96" y="1" x2="96" y2="28" eletype="LN" valuetype="FX" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="1" color="FFFFFF" x="183" y="1" x2="183" y2="28" eletype="LN" valuetype="FX" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="104" y="8" fixedtext="true" daynight="false" eletype="FX" text="00" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="176" y="8" fixedtext="true" daynight="false" eletype="FX" text="00" font="XTINY" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="40" y="72" fixedtext="true" daynight="false" eletype="FX" text="00" font="SMALL" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="139" y="72" fixedtext="true" daynight="false" eletype="FX" text="00" font="SMALL" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="240" y="72" fixedtext="true" daynight="false" eletype="FX" text="00" font="SMALL" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="40" y="116" fixedtext="true" daynight="false" eletype="FX" text="00" font="MEDIUM" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="139" y="116" fixedtext="true" daynight="false" eletype="FX" text="00" font="MEDIUM" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="240" y="116" fixedtext="true" daynight="false" eletype="FX" text="00" font="MEDIUM" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="40" y="173" fixedtext="true" daynight="false" eletype="FX" text="00" font="LARGE" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="139" y="173" fixedtext="true" daynight="false" eletype="FX" text="8" font="LARGE" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="240" y="173" fixedtext="true" daynight="false" eletype="FX" text="00" font="LARGE" halignment="0" precision="0" nr_values="1" sampletext=""/>
    </DIYLayout>
    Code for the middle picture:
    <DIYLayout>
        <LayoutElement type="0" color="FFFFFF" x="39" y="50" fixedtext="true" daynight="false" eletype="FX" text="00" font="NR_MILD" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="139" y="50" fixedtext="true" daynight="false" eletype="FX" text="00" font="NR_MILD" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="240" y="50" fixedtext="true" daynight="false" eletype="FX" text="00" font="NR_MILD" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="40" y="91" fixedtext="true" daynight="false" eletype="FX" text="00" font="NR_MEDIUM" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="139" y="91" fixedtext="true" daynight="false" eletype="FX" text="00" font="NR_MEDIUM" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="241" y="91" fixedtext="true" daynight="false" eletype="FX" text="00" font="NR_MEDIUM" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="38" y="132" fixedtext="true" daynight="false" eletype="FX" text="00" font="NR_HOT" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="139" y="132" fixedtext="true" daynight="false" eletype="FX" text="8" font="NR_HOT" halignment="1" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="242" y="132" fixedtext="true" daynight="false" eletype="FX" text="00" font="NR_HOT" halignment="0" precision="0" nr_values="1" sampletext=""/>
    </DIYLayout>
    Code for the right picture:
    <DIYLayout>
        <LayoutElement type="1" color="FFFFFF" x="0" y="230" x2="280" y2="230" eletype="LN" valuetype="FX" daynight="false" radius="0" stroke="1" nr_values="1"/>
        <LayoutElement type="0" color="FFFFFF" x="38" y="9" fixedtext="true" daynight="false" eletype="FX" text="00" font="NR_THAI_HOT" halignment="2" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="243" y="61" fixedtext="true" daynight="false" eletype="FX" text="00" font="NR_THAI_HOT" halignment="0" precision="0" nr_values="1" sampletext=""/>
        <LayoutElement type="0" color="FFFFFF" x="139" y="140" fixedtext="true" daynight="false" eletype="FX" text="8" font="NR_THAI_HOT" halignment="1" precision="0" nr_values="1" sampletext=""/>
    </DIYLayout>
    After uploading to your watch and make a screenshot you have to adapt the layout in the designer to match the look at the watch - even if the positions are not right. But you have to do it by editing the fonts.txt offsets - not by changing the x/y coordinates in the designer!
    Or you submit the screenshots and I'll do!  Wink
  • I have just checked the original fonts.txt which is delivered by HM when downloading the Designer.
    For Fenix 6X the font mapping was already done - and now I don't know if my fine tuning for the "normal fonts" is even better?
    For the NR_Fonts I did no change in the fonts.txt!
  • Hi
    I already did the mapping for the F6XPro. The bigger fonts do not look exactly like on the device, because the font used there is not available and I did not find a better fitting one. So, the preview for the bigger fonts is as close as it gets for now.
    Sorry for that, but the original garmin fonts are just not available.
  • feature request:
    There must be a way to capture peak Power and HR values for a given interval during a ride, there are several apps allowing it (eg Powerfield, Link, source code is available)
    So eg. if you choose 1 min, I know you can get the average HR or Power with "nr of values", but what about the max 1 min value for the ride?
    Thanks!
  • Hi! it's possible to show the value of w/kg ??? only put a formula to divide watts and your weight. thanks a lot!!!
  • Hi
    On which power value should the value be based on? Normalized or the standard bike power?
  • if is possibe, in the two options, and anyone chose standrd or normlized. thank you so much
    Got a few value requests for ya.
    • Time until sunset / Time until sunrise (without optional offset)
    • Steps for current activity (as opposed to daily steps)
    • Steps until daily step goal
    • Weather related fields (assuming phone & data connection)
    Also, how are you able to add symbols, like the heart or battery icons?
