Keep in mind posts like this may violate the terms of use on the Garmin forums: https://www.garmin.com/en-US/legal/terms-of-use/
					Not sure why you'd exclude cloud in 2019 as that's the normal way to build such a solution. My Event Hub App in the store allows all sensor data to be uploaded in real time from as many watches/devices…
					Did you see the discussion here for Matlab:
https://www.thisisant.com/forum/viewthread/7074
Open ant:
https://github.com/Tigge/openant
and Python ant:
https://github.com/mvillalba/python-ant
Live ANT+ Data:
					It would be great to have such an application, WoWce 8. I m also interested in such a project. We need to swich on Ant+ broadcasting on the Garmin watch and and need an Ant+ dongle.
I ended up being happy with the project of the ANT+ Virtual Power Meter as an example:
The project is designed to run on Linux. But I think it should be possible to modify the example to create a windows application out of it.
Not sure why you'd exclude cloud in 2019 as that's the normal way to build such a solution. My Event Hub App in the store allows all sensor data to be uploaded in real time from as many watches/devices as you want and can then visualise live in Power BI (or some other system). I've also created a demo to mix this with machine learning to analyse data in real time.
					No, I don t want to exclude a cloud solution, great that you have a cloud solution.
had a solution with a server. Unfortunately, it is not free and open source anymore. I was not able to convince Nils Knieling to bring it back:
This is a pity. I think his solution would have worked for Matlab and I loved it.
					your EventHubApp
https://apps.garmin.com/en-US/apps/b27ddfe5-e5f7-4754-94ce-ce3007fe49b9
is interesting, lustyd , thank you for sharing it. I will have a closer look at it.
