I have multiple users complaining watchfaces are showing the IQ! symbol since their firmware update to 7.20. But I don't see any reports in ERA... Any others that experience the same? Wondering why it's suddenly crashing since that update.
Maybe they put the same bugged code like in f6:
and the best is that there was…
it never happens also on mine but I've seen a lot of thread about this on social network and everytime solved with a reboot which is always higly recommanded agfter a fw update.
and this kind of crash…
Thank you for sharing this error. I'm also just getting more info from users are willing to test side loaded debug versions that the fonts seem to be the issue. This is a huge problem for me as I seeing…
Have you tried "contact developer" for the app you are having a problem with? This is generally due to a hand modified custom font. See https://forums.garmin.com/developer/connect-iq/i/bug-reports/fr645-and-others-since-fw-7-20-major-issues-with-custom-fonts
Point the developer to that bug report. It was easy to fix in my watch faces.
I fixed the Bluetooth. For the record here is how I did it in case somebody has the same issues after a firmware update:
1) Remove your Bluetooth Garmin watch from your Android Phone known devices (Go to settings -> connected devices -> previously paired devices, select the watch  and click FORGET). This will also remove the device from your Connect app
2) Reboot the phone
3) Put the watch in pairing mode: Settings -> Phone ->Pair Phone
4) Open your Connect app and pair a new device. The app should find your watch and guide you through the registration process.
Will it be fixed and when? Garmin, what is going on?
