Has anyone been able to use the custom watch faces?
I get an IQ Error since the update.
I can only get the ones that come with the watch working, even Garmin newer don't work.
Hello,
My Sensor Hub SW is 22.09 (Enduro watch).
Anyway, to me it's definitely something related to the watch face getting location from 'ActivityInfo'.
On a watch face I'm developing I have…
All my personal side loaded WF's are working on 25.00 without issue on my F6Pro. I just went and installed Crystal, and it is also working. I did verify my Sensor Hub SW is 22.09
This is bad, but it…
TheSaintr no crash for me with Lachesis Light, 7h hours later
do I understand correctly that none of the CIQ (downloaded) watchfaces work, and all of the built-in do work?
This sounds pretty much like the problem I reported on 24.81, and that was supposed to be fixed in 25.00.
Can you check on your watch (when connected as USB drive to a computer) if you have GARMIN/APPS/LOGS/CIQ_LOG.YML and/or CIQ_LOG/BAK? If yes please send us what's in it
Can you install my PSX-6 WF and check (I can't install such bugged firmware because I need a working watch to test my apps)?
I'll be watching the ERA logs, so maybe I'll find the problem. After a possible crash, you should synchronize data with GCM to expose crash logs.
Thx.
