I am going to try something. Will DM you. Are you willing to help me troubleshoot?
hi Jim, I installed the new SDK but no ERA in my meny and no Eclipse plugin available.
did I do something wrong?
hi, exactly the same for me, have you found something?
When you installed the SDK, did you also install the new eclipse plug-in? That is what adds the CIQ menu in eclipse.
ERA is for ciq_log files that are automatically pulled from user devices (that came from the app store).
Sounds like you have a music device and a mac. They use an MTP format, and on a mac you need something like AFT - https://www.android.com/filetransfer/ to access the device.
When I wanted to install the new plugin I was said nothing new...
In eclipse when you run help->about->installation details, it will tell you the version of all the installed plugins. Do you see this? The CIQ plugin should be a 3.1.3.
After investigation I found a refresh button and I was said update available, cause I was on 3.0 and now like your pictures. Many thanks
Brandon.ConnectIQ Former Member Former Member Petr.Koula
Any chance you guys share your findings with us?
