Hi,
all of sudden my app started to give errors (300, NETWORK_REQUEST_TIMED_OUT) on the following code:
Log(url);
// Make the request
Comm.makeWebRequest(
url,
"Content-Type" => Comm.REQUEST_CONTENT_TYPE_URL_ENCODED
method(:onReceive)
Hi,
@FlowState, indeed, switching to Let's Encrypt certificate has cleared the "Network Timeout -300" error, the widget is now working correctly.
It would be nice to:
1) have a more descriptive…
HI,
GCM version i do not know. Is this part of Google play services (my version is 17.7.85).
I indeed do have parameters in there. I will try to move them to the empty {} in the call
Kind Regards
Arn…
Ask in the bug report thread I linked to, And "up" the first post in that thread, as it shows how many people are having problems with 4.20.
This could be related to which GCM is being used. iOS vs Android. So you may want to ask that as well as which version of CGM.
My guess is it could have something to do with "url" in your code. Are you including parameters there? If so, you want to remove them from the url and specify them as parameters (the empty {} after the url in the call)
Hello,
You are not alone :) have suddenly the same exact problem with the widget I developped for my personnal use.
I tried to restart the vivoactive 3 and the phone, but problem is still here...
aha.. sorry.. you mean "garmin connect mobile" with gcm. I thought you were referring to "google cloud messaging" :-)
I made the code change, behaviour is the same
https is not an option, i have no ssl certificate. It should work (and it used to work without code changes) for http
tx for feedback. I hope it will be fixed.
i already found another thread with the same problems:
See
There's a link from 2017 in my post there you may want to look at. See the "Changes to makeWebRequest" section.
