Anyone have this working with 945? Do button controls work? Specifically can I change volume from earbuds (Doing from watch is hazardous while running)?
It was working just fine for me. Until 5.30, and now it keeps disconnecting during my runs :/
I have definitley discovered how to make this issue turn 'on/off' if you will. Bottom line, any time I have the phone connection enabled on the watch, s&%t happens. However, if my phone blue tooth is disconnected…
Urgh!!
As some may recall I had this problem and it went away completely. It's been at least a couple of months and now it is back with a vengeance.
Generally after 5 minutes music will just stop and…
That sounds like someone who hasn’t bothered to check the issue properly. EDIT - sorry, I misread that as garmin rep!!! Ignore that comment LOL.
As an aside, my recent set had no issues in this regard but the case stopped charging. I exchanged them for a new set yesterday and the right earpiece does not work at all. I’m picking up yet another new set later today.
If I didn’t love these earphones so much I would have gone with a different set by now.
I have also recently had a replacement pair, but it seems I am having the exact same issues with disconnection. I was hopeful after reading a new pair remedied someone's problem.
Agreed, the headphones are great on every other device for me, and great before this issue occured.
I have definitley discovered how to make this issue turn 'on/off' if you will. Bottom line, any time I have the phone connection enabled on the watch, s&%t happens. However, if my phone blue tooth is disconnected and also the watch phone connection and I simply connect the Vistas via the watch music process, all is well. Yes, I can make things revert to music stopping by enabling the phone connection on the watch, even if the phone is 5 miles away!
It didn't work for me. I disconnected the watch phone connection but the earbuds disconnected. I didn't disconnected the bluetooth of the phone because I need it for other things.
I continue to experience the same strange behaviour: some days the earbuds don't disconnect, some days they disconnect. Very strange issue
Yeah, I've only found 100% success with both phone and watch Bluetooth in the OFF position. However, that works for me because running is segregated from all other stuff!
I just asked about it here https://forums.garmin.com/sports-fitness/healthandwellness/f/vivoactive-3-3-music/257426/vivoactive-not-pairing-with-jaybird-vistas-anymore/1303726#1303726
I don't have my phone nearby, and my watch is not connected to my phone at all, and I still get the disconnection issue.
Vista 2 has the same issue, don't buy that for Garmin watch.
