i can no longer connect my HRM run to the 945. I changed the battery, tried to refind even broke out my back up and tried to connect to no avail.
Is there a known issue here? Or am I the lucky one to figure it out? Or . . .
This is a bug, I can only use my HRMRun ONE time, then need to reboot the watch to connect it again. Firmware 2.50.
So on every run I need to:
- Reboot the watch
- Sync with GC as to have heat acclimatation…
When I select the Activity (so fx. run or walk)
1. With Wrist HR - there is no "Heart" symbol showing (When you are IN the activity before pressing start - the screen where top line say "Options…
Works fine for me, I always run with the HRM strap and had been getting the "external HR connected" message with the old (old!) HRM strap I was using. I just bought the HRM-Run (the latest, the one with…
Be nice if there was some sort of indicator next to the heart icon indicating an external source,
I never get a heart icon on my screen prior to starting my activity when the watch is connecting to sensors if I'm using the WHR. The only time I see the heart icon is when it connects to an external HR monitor.
- Reboot the watch
- Sync with GC as to have heat acclimatation data (yes i'm running over 30° here)
- Start activity
LOL? NO!
I'm a software architect (it's 25 years i develop software)...I will be able to fix all these bugs in days, Garmin are you joking on us? (written by an old time customer of garmin trackers too). Need a pro dev?
Marco Ziliani
I have that problem, too. When I start a run, I start it with the start button and when the GPS signal is found, I go back to clock mode with Back Button and then start the run again. And then the HRM Run will be found immediately. The clock does not have to be restarted.
Oh, this explains why I never encountered that problem with my HRM-run: I use the 945 only for running and power it off after use. So by accident I did what you described :-)
