I just purchased a forerunner 55, and the distance is not showing on the watch or in the app, when I went for a long walk earlier. Any ideas?
Did you record your walk as an activity?
Yeah, I did, I tried resetting watch, back to factory resets, and it seems to have done the trick. Thankyou for your reply
A noob here. I did a walk and saved it. How do I get to see the exact distance I did on the watch itself? I found steps and a chart display of distance in the watch but it is approximate only.
Assuming you recorded an activity as mentioned above, I would typically use the History widget or the Last Activity widget.
Forerunner 55 - Widgets (garmin.com)
History - Displays your activity history and a graph of your recorded activities.
Last Activity - Displays a brief summary of your last recorded activity, such as your last run, last ride, or last swim
OK, thanks for replying; that's what I was looking at. Just that apart from the steps, which are exact, everything else is just a rough showing, not like the specific data readout that the watch was showing when I pressed Stop.
I guess that's just how it works in the history part for walks.
For more details I would use the Garmin Connect Mobile app and/or Garmin Connect Web.
Thank you, I did an interval work out today and looking at the history, it now has the exact distance for yesterday's walk. So it not appearing there before was just a blip. About to use Garmin Connectt today to set up my training runs. Fingers crossed
