Garmin HRM-Dual not working after less that 1 year. Should i change the battery? The spec states battery should last about 2-3 years. Any advice?
We recommend replacing the batteries & performing a reverse polarity on your Heart Rate Monitor (HRM) by following the steps below.
Please follow the steps below to perform a Reverse Polarity on your…
Mine show 72bpm and stop.. done this procedure and now doesn't connect to my edge.
Quite disappointed
Exact same issue here, and it used to work fine. Now it connects, shows say 72bpm for a few seconds, then nothing more. Have done the battery-flip reverse polarity solution, no joy. This is also with a…
I totally agree with you. I don't know how many times I have reset the HRM only for it to happen again.
Garmin need to take responsibility for this issue
Thank you!!! This worked also for mine!.
Stil not working. Polar h9 was 100 times better than this one. Always not connecting i did everything that I could. Sometimes it s on sometimes(most of the times!!) not connecting Frustrating as k
Stopped working in less than 1 year. Reset + new battery does not work. First it shows only 72bpm, then Edge Explore 2 randomly shows heart rate for short amount of time and then just stops showing it even HRM stays connected. Phone does now find HRM at all anymore.
This product is pure trash.
No, cannot confirm that.
I own a HRM Dual since around four years and use it on a regular basis. Changed battery 3 or 4 times and it is still working fine.
Maybe there is a problem with some batches...
Android users:
There is a setting to do a full reset of Bluetooth and Wifi on your device. This is apparently not the same as just pressing forget on a device in bluetooth settings. Google on "reset Wifi & Bluetooth on Android".
It worked for me on two devices running Android 13 & 15.
I had HRM Dual in the past, but at some point I got tired with the problems described in the thread and get myself Polar H10. Since then I had no issues at all for maybe 3 years or so. So when people ask me for suggestions I recommend Garmin MIPs watch models and but always advise to save money for Polar and don't invest into Garmin HRM...
And because my poor experince with HRM Dual which I could use around 1.5 year before it started to show unrealistic heart rate even with new chest band, I would think twice about getting myself new HRM 600. Maybe if there would be not many problems reports, I could give it a try...
this is total BS. You cannot reverse the polarity due to how the connections on a CR2032 are made. reversing the sense of the battery results in a short circuit ie 0V nothing more.
Trying to understand how does the reverse polarity works, as when you flip the battery, positive side is touching both contact points... There no contact with the bottom or negative side...
thank you so much for this help regarding resetting my hrm. very grateful
