Dear Community,
Since yesterday i've got my Vivoactive 4s. Today at 11am i've charged it 100%. Now, at 4pm Battery Level is 55%. Just in Smartwatch mode
SPO2 is off. Wlan, Musik never used.
Whats up?
Are there someone else with this Problem?
Dear Community,
Whats up?
This is happening to me too. I just received my 4s yesterday. Charged it to 100% at around 1800 last night, when i went to bed at 2200 it was 87%, and I thought that it was because it was new, I had just…
Garmin released an update version 3.30 that claims to fix battery drain issue with IQ Connect watch faces. I put the Lacesis face back on and will see if battery usage changes. The last charge I did to…
This watch is a mystery to me. All I can really suggest is to stick with it and eventually the battery drain problem might resolve on its own. I got my 4s in September right after it was released and now…
Not completely. Modern chargers can provide way above 500mA. Some fast chargers are even increasing voltage above 5V. 5V/500mA is/used to be standard for USB. If you connect device which has not properly implemented charging to such charger, may pull out more than 500mA. Charger can even wrongly detect device and provide higher voltage. Consequences are pretty obvious.
Smart watches have tinny battery, not much space for electronics, over voltage/current charging protection and can be easily damaged. And in general, batteries do not like fast charging, regardless what marketing says.
Well I have done nothing but charge my 4s with an Anker power strip w/USB port, have never used a fast charger, and the battery life has never been adequate.
If it is so easy to fry the battery then Garmin needs to put a warning in the product IFU, and also not have their tech support tell us to charge for 4 hours.
To give it one more chance before you feel you need to return it, try the suggestion earlier in the thread - after making sure you have updated to the newest firmware, on the watch do a full reset, then charge the watch for at least 2 hours *after* it says 100%.
Choose one of the built in original watch faces that do not show seconds (or turn the seconds display OFF).
With bluetooth and notifications ON, pulse-ox OFF my test made it to 5 days and still had 42% left, calculated drain was .5% per hour.
If you try this test it should give you a baseline as to whether the hardware itself is at fault or its something else.
