speed variation
Hello, 2 day owner of edge 530 and my problem is showing speed variation, i use a GPS+Glonass + speed sensor, sw 6.0, and my showing speed vary from 34,5 35,3 36,7 38 and again 34,6 35,8..... hire is a short video what show my edge
https://drive.google.com/file/d/1lUl_6ulPjv9RAlKoQDu-pr3WTIu8kn0s/view?usp=drivesdk
Top Replies
All Replies
    0 Former Member over 5 years ago
    hi,
    care to share the make and type of your speed sensor ?
    placed front or back ?
    paired ant or ble ?
    was the non stable speed during the whole ride or just on that part of the ride ?
    what kind of street surface were you on at this time ?
    happy & safe sporting
  • Hello, i use a bundle speed sensor 2, connected over ant+, placed on back hub like before, the surface was flat no holes, and this is all two days rides, if speed up speed is increased no variation only when i riding on same speed
    0 Former Member over 5 years ago in reply to veskox
    hi, thank you for the feedback
    • care to explain the "like before" part ?
    • what kind of material is the hub made ?
    • what is the make and type of your wheel set ?
    • and last the chain make and type ?
    • what make and kind of cadance sensor ? from the bundle ?
    connected over ant+
    • also connected to the phone ?
    there is one other user who has more or less the same speed variation
    found good install info
    I Am Getting Inaccurate Speed Readings from My Garmin Bike Speed Sensor
    If the Garmin Bike Speed Sensor (BSS)  or Speed Sensor 2 is not providing accurate speed information, review the following steps which will solve most problems:
    1. Ensure the device is configured with the correct wheel size. This setting is typically automatically set by the sensor. Refer to the device Owner's Manual for details on wheel size and circumference.
    2. Remove any magnets installed on the bicycle.
    3. Place the sensor on the front wheel of the bicycle. This will move the sensor furthest from any components which may be magnetized.
    4. If the sensor must be placed on the rear wheel (indoor training), place the unit with the sensor's LED closest to the cassette. This moves the magnetic sensor further from any potentially magnetized components.
    5. Leave the sensor stationary for 3 minutes after installing it, and then try again. This allows the sensor to re-calibrate its internal settings to allow for bike-specific differences and minimize the effect of any magnetized components on the bike.
    6. In some geographic locations in Ecuador, Peru, Brazil, or other locations, the earth's magnetic field is relatively weak and oriented in a north-south direction. This makes it challenging for the BSS to accurately detect wheel rotations when moving in an east-west direction.
  • placed on back hub like before
    before my edge 530 i used mode than 3 year edge 820 bundle, my speed sensor first was speed sensor gen1, and after this i buy a speed sensor 2 all sensor was placed on the same wheelset with aluminium hub
    hub material is aluminium
    fulcrum racing zero DB carbon using 1,5 year
    KMC x11
    yes i use speed sensor from the bundle, i have one more and will try another one
    connected over ant+
    yes connection to phone was BLE , sensor was connected over ant+
    i will reed this one
    one more thing what i will do and write after , put to recalibrate wheel size, to check is ok , if is not ok i will disable speed sensor to check if only on gps will be ok.
    If someone have other idea let me know
    was is set to autocalibrate ?
    • disconnect the sensor from the phone
    • check with your gen 1 speed sensor
  • was is set to autocalibrate ?
    yep first ride was auto calibrated after 500m
    sensor not connected to phone only with edge
    i was sold speed gen 1 have one more speed 2 and will try
    • turned it off afterwards ?
    what you mean to tuned it off edge or sensor ?
    first ride, connect all sensors, waiting gps, and go starting after 500m wheelsize auto calibrated and that`s it
    • turn auto calibration off
    read this ... edge-130 - reset-tire-size-for-new-bike-necessary
