speed variation
Hello, 2 day owner of edge 530 and my problem is showing speed variation, i use a GPS+Glonass + speed sensor, sw 6.0, and my showing speed vary from 34,5 35,3 36,7 38 and again 34,6 35,8..... hire is a short video what show my edge
https://drive.google.com/file/d/1lUl_6ulPjv9RAlKoQDu-pr3WTIu8kn0s/view?usp=drivesdk
Top Replies
All Replies
  • Thanks, tomorrow i will try all thinks and will tell what's going on
  • Today i test my 2 sensors , on front hub and rear hub, auto and manual wheel size and the problem exist, the this when i see on my fenix 6x is the same sensor have a different wheel size fenix show from 2088 to 2108 edge show from 2138 to 2110, if i disable speed sensor, speed stop go up and down
    0 Former Member over 5 years ago in reply to veskox
    hi,
    • was this after or before you followed the "how to manual calibrate" in the provided link
    • are speed fluctuations on both fenix and edge ?
    • was this while the speed sensor 2 was paired with the phone ?
    • speed sensor 2 has the latest firmware ?
     and Former Member can you two compare serial numbers from your speed sensor 2
    best bet until now is going for an exchange ?
    happy & safe sporting
    0 Former Member over 5 years ago in reply to Former Member
    Not sure if this is the serial number, but on the box it has the number 010-12845-00. Otherwise, the Gen 2 speed sensor does not have a serial number than I can find.
    yup today more than 2h i play step by steb instaling speed sensor from bundle and old one again version 2
    only on edge 530 have problem with showing speed
    speed sensor never connect to the phone before now i connect to phone no update
    up to date
     and  can you two compare serial numbers from your speed sensor 2
    serial 3335750715 this is on speed sensor 2
  • for me the problem is in software in edge 530 with two sensor speed is go up and down, one of sensor wirk perfectly with old edge 820 and fenix 6x, now new and old sensor work perfect with fenix 6x, maybe for now solution is to desable sensor and waiting new software releases and crossing fingers to this was fix or upgrade will be big mistake
    hi,
    most likely it is software related
    • only possible to check with a software downgrade
    • downgrade let's you lose all settings !!!
    edge 530
    edge 820
  • Hello,
    today i play with sensors, and gps and got working but only in one case, doesn't matter on which wheel is sensor if the edge is mount on stems not working, this was try with 2 sensors v2 only working if i using extended mount and sensor is placed on front wheel, for me this is bad signal or antenna of edge 530 my old device edge 820 worked purfect rear wheel sensor extended mount or stem mount, in this situation can't riding my bike on trainer and using sensor on rear wheel but how ever this was not problem on garmin. This was my 2 cent's
    hi,
    nice test
    how about returning the 530 ? option ?
  • hi, returning is not a cheap option, half of the price, how ever on front wheel working, for now that it, cheers mate
