Do you have a similar experience?
Personally I don't. Can't you simply stop GC (swiping it up in the task list), when you see it happenning? When you stop it, and the location service continues draining the phone's battery, there is probably…
Same, mine drains 1%-2% per hour as well doing nothing. I'm on 12.00. On reddit, someone who has the 5S+ said they narrowed it down to the 12.00 update being the culprit for the battery drain. He downgraded back to 11.74 and his battery life is back…
After the s/w update for 4.90 on the V3A Music I've noticed considerable battery drain as well. I'm getting a bit over 24 hours off a full charge. I used to make it 2-3 days depending on how long the activities were I was doing with music and gps.…
Hi, today i have coupled the HRM belt to FR255. All OK but the sensor configuration with ON to the search mode decrease, after one hour, the battery percentage of 1 % even with belt uncoupled. Without this configuration and all normal sensor (excluded saturimeter…
this is encouraging. as i posted in a separate thread, i was looking to see if anyone has had no issues with the latest FW and it seems you are experiencing battery drain similar to my watch running FW13.30 (i do have bluetooth connected). gives me hope…
I've experienced a similar increase in battery drain since updating to Beta Version 15.06 despite soft resets. See the Public Beta bug Reports 15.xx
Hey there, could not answer other topics because mods locked them. Garmin Kevin says that we should delete every ciq aps from the watch to resolve battery drain problem. I know he talked about watch faces but What about spotify and watering reminder app…
Todayi installed 14.36 at noon. At 17:00 I discovered that I have 10% battery. I thought it's odd but I charged it to 81%. I went for a 2h run, the battery dropped to 56%. I did 2 breath work exercises and now the battery is at 47%.
What is going…
Also huge battery drain since a few days. Beside that having Bluetooth connection issues. After a full reset the Bluetooth worked again for a few hours but battery drain ist the same.
