Hello, my Vivoactive 3 battery drains so fast. When GPS is on my battery is discharging 27% per hour. Are you experiencing the same?
New 255 battery drains rapidly, not sure which settings are driving this
I have turned off gestures, thinking this may be the reason
Not happy as I really like this feature
Have done the soft reset and software up to date
You have permission to email…
Please see the full discussion for this report:
And again with the new firmware battery drain is back...
I went to sleep with more than 70% and woke up at 16%.
Not good... We can't have this kind of problem on a device that is on the market for a year
I am getting about .5% per hour battery drain with 11.17 in the last 5 days. Anyone else notice higher then normal drain?
Hello,
It has been weeks and I cannot use my watch because the battery drains in less time than it takes me to do a 5k run (30 minutes).
I am very frustrated, I have tried a factory reset, nothing works.
I have a vivoactive 3.
Please advise,
Asia Har…
In the past few days I've noticed an incredibly fast battery drain. I started with 100% this morning and I'm down to 75% without recording any exercises. Yesterday it drained from 65% to 20% after using it for a 45 minute run. I've seen several old posts…
I went for a 40 min run Saturday, with battery showing 25%. After the run, the battery-level had dropped to 3%, where it stayed for 2 days (now charging).
Not sure if this is a bad case of battery draining or just the indicator not working correctly on…
