• RE: Garmin Venu Battery Drain 10/2020
    Try to do a factory reset maybe this will solve the problem. I suggest you create your own watch face using the 'Face it' tool if you need the battery not drain fast in general. my venu can stay seven days at one charge if I use my custom watch face.…
  • RE: Battery drain after workout since fw 12.20 - reproducible issue
    battery drain since firmware update 12.20.
    I had the battery consumption problem with the 11.75 beta. Reverting to the baseline FW solved the problem, now running 12.20 without an issue.
  • fēnix 6X - Pro - Battery drain
    The watch is struggling to stay connected to my phone and I have to keep entering the serial number a few times a day.
    Latest software on phone (android Samsung A3) and watch.
    Battery also drops drastically 5% a hour at the moment>
    What I have done
    Factory…
  • RE: Massive battery drain with Fenix 7X Solar Sapphire v9.33.
    Updated October 4th, 2022:
    If you are using Strava segments, the issue was resolved updating to software v9.36.
    If you continue to experience fast battery drain using v9.36 software, this thread is being monitored and updated:
    Fenix 7 Series v9.36 Fast…
  • Battery drain 0,6 / 0,8 per hour - Fenix 6 Pro Solar
    Hi All, I have a battery drain between 0,6 and 0,8 per hour on Pro Solar with 24h HR on, notify off, bluetooth on,GPS off and OX Pulse off, is it normal?
    What I can change to reduce the battery drain? Firmaware 11.10.
  • 23.84b Accelerated battery drain continues
    My 6X Pro Solar has been used purely as a smart watch without recording activities since fully charging two days ago.
    Down to 85% and 18 days remaining after 48 hours, so that's 7.5% per day or 1.5 days per day. This is nowhere near the advertised spec…
  • Fenix 5 plus battery drain
    I bought a fenix 5 plus a few weeks ago. Everything was fine until some point, I think some update. From that battery life decreased a lot.
    It's dropping by 30% a day!! I tried factory reset, updating to the last beta. Deleting all the widget and using…
  • Anyone switched to 28.01 and had battery drain with 28.00 before?
    With 28.00 I had massive battery drain. Changelog doesn't mention any fixes in regards battery. Did anyone switch to 28.01 with solved battery drain?
  • Battery drain and Activity sync
    Hey Garmin! People are complaining a lot about the two issues in subject.
    I had to install and reinstall the app several times to make it working again but not sure for how long.
    Sometimes on my Samsung it eats up 30% battery in background.
    Also, the…
  • Possible cause of Battery drain
