Since installing the beta 25.76, the battery drains more than twice as fast, the same settings as in version 25.10 over 0.65% per hour. In version 25.10 it was about 0.30% sometimes less per hour.
I have been using my Solar for nearly 4 months and in the last 4 discharge cycles have given me closer to 25 days battery life with following profile.
1. Average 1 hour Non-GPS activity.
2. Pulse Ox turned off.
3. HR, Sleep, Steps tracking ON.
So there…
So that this no longer happens I have to disable Bluetooth on the iPhone
Right. For me, the constant disconnections are to blame for a consumption of about 2 percent per hour.
In the video, look for the green dot of the connection indicator…
My Venus SQ is 2 days old; brand new. After 1 day of full charge, battery drained down to 20% and I only recorded an hour walk activity. I downloaded one face on IQ store the day before. Now, watch is stuck with charging icon, refusing to turn on, and is…
I've had this problem for the last 4-5 software updates. I noticed that the battery drain happened over night, at least that's when it was really bad. I suspect that it could be related to the sleep tracking, but I'm just guessing.
I'm assuming…
For your information Fenix 8 / Enduro 3 / Fenix E just received 11.64 with Battery Drain and Naps fixes.
Garmin-Sierra, Garmin yes you can, all FRx55/x65 are waiting for your feedback for a fix too
Apparently this was resolved with yesterday's 17.04 update. Anyone noticing an improvement in battery life? Mine was draining 50% per day (with AOD on), now came back to the 35% day like before
Last time I tested the old stopwatch was on a Fenix 6 pro and it was using ~0.5%/hr. Never tested on the FR955 but ~0.5% feels right based on my experience. The difference between the old stopwatch and the new one is significant enough that I immediately…
Same issue for me a couple weeks back.
I fixed it with a full reset - see this thread for details (last post from me has a summary)
forums.garmin.com/.../solution-to-battery-drain-new-issue-for-me
I see the same problem: when I edit activities via GCM, for example adding data pages and fields to trail running or running, battery consumption increases rapidly. I rebooted the watch after two hours and 11% battery drain.
