Touch screen fails to enable: F8 43mm 13.37
"Touch" shortcut shortcut is set to START+DOWN button combo.
Issues:
  • Touch screen is not enabled via shortcut unless the screen is cycled on/off.
Video demonstration attached
Fenix 8 AMOLED, 43mm, FW ver. 13.37
Additional notes:
  • if shortcut is triggered while Controls menu (circular menu) is open - pictogram does not correctly reflect ON/OFF status
  • if shortcut triggered while an activity is running it affects activity's setting rather than global touchscreen status
    • e.g. if touchscreen is enabled -> start an activity (e.g. walking) -> shortcut "touchscreen" to disable touchscreen -> hod LIGHT to go to controls or get to main watchface or any other non-activity screen ->touchscreen is disabled
Similar issues reported prior:
As per Garmin affiliated comments on some tickets linked above the fix is currently expected somewhere mid-May.
