Since today, Yesterday was fine.
My watch crashes when going to the activity screen. Blue triangle and restart.
Hello. I am sorry to hear you are having this issue. Our engineers have identified an issue that may crashing/rebooting when navigating or using the map. They are anticipating a fix for this to be introduced…
It is a problem with a faulty GPE file. Fenix/Epix series can be fixed without hard reset. - Connect the watch to the computer - Hard power down the watch by holding the light/power key for ~30 seconds…
Yes. The same happens here. I’ve tried to do a soft reset, but now my watch is stuck in a loading maps loop where after the maps are loaded, it says ‘checking maps’ and then powers off to a blue triangle…
Same here. My watch is looping through the following sequence: blue triangle - Fenix 8 animated logo - checking maps - power off - blue triangle - Fenix 8 animated logo, etc etc.
I've tried powering the…
I have the same problem since today. Yesterday was all fine. Maybe a software update?
same here, I can't start any activity on my Fenix 8 Solar, keeps rebooting.. nice one Garmin. Worked fine yesterday, today I can't do anything. (software 12.35)
update: I just enrolled in the Beta program and updated to v13.18 and the problem goes away.. no rebooting on activity. So Garmin have pushed out a dodgy update I think.
update2: I'm now on beta v13.21 and everything is working OK still
Same problem. Yesterday everything was fine ... today it didn't work
The same with beta 12.18 and map app and activity apps. Trying to start anything watch reboots.
Yes. The same happens here. I’ve tried to do a soft reset, but now my watch is stuck in a loading maps loop where after the maps are loaded, it says ‘checking maps’ and then powers off to a blue triangle, powers up again, then starts loading maps. And round and round it goes.
same issue here now.
My advise, switch of auto update for starters. Don't pley around when it does not work. Only made it worse for myself. settings recovered. Still cannot start activities though
It happened once to me, after update. When I went outside, prepared for run, then selected Run activity and saw triangle. But it never repeated so far.
I have the same problem, it worked sunday but not today. It seems to be related to GPS, because I was able to record my run without GPS, just using distance from Stryd footpod. I'm on 12.35, GPS: 2.11, Wi-Fi: 28.84, CIQ: 5.02, BMX: 18.1.4
Same here and called helpdesk who confirmed, broad and known issue and ticket been raised to solve it asap
