Cold water crash
My Fenix 8 AMOLED 47mm consistently crashes when the water temperature drops below 8°C.
This is a significant issue where I live, as the water temperature often falls below that.
Interestingly, after a crash due to the temperature drop, the watch can usually reboot and function properly, even if the displayed temperature is below 8°C.
In Europe, dive instruments must be tested down to 0°C to be on the market, so I find it surprising for a watch advertised to operate in negative temperatures to have this problem.
I've noticed other users reporting the same issue on Reddit.
I'm wondering if this is a software safety feature that might be resolved in an update, or if I should consider sending the watch back.
It seems the watch can operate in low temperatures, but the sudden temperature drop when entering the water causes it to crash consistently.
  • No, this comes straight from Garmin… unfortunately I can’t attach the file but this is the email straight from them:
    “Thanks for contacting Garmin Product Support. I've included the steps to use that file below and included the file here as an attachment.
    The following steps will allow you to calibrate the buttons of your watch and possibly resolve the button issue you are experiencing.
    1. Plug your watch into a Windows PC or a Mac that has the ability to read MTP devices (a third party program may be needed for your Mac to see the watch as a drive).
    2. Locate the drive for your watch on the computer, and open the drive.
    3. Place the KEY_CALIBRATION.BIN file in the Internal Storage of your watch. It should not be placed in a subfolder.
    4. Disconnect your watch from the computer.
    The watch will go to a button calibration screen. Press each button fully a couple times. A green check will appear when the button is calibrated.
    After calibration has completed, turn off touch on your watch, and test the buttons to ensure they are working.
    If the buttons are still not working, let us know.
    Thank you for choosing Garmin,
    Austin
    Product Support
    Garmin International
    For 24-hour access to support videos, manuals, FAQs & more, visit the Support Center”
  • But I also think that
    I'd imagine that a dive rated watch that costs $1100 shouldn't display issues such as this one. Nor should the user try calibrating anything.
    Should not, but it happened. Anyway, now you have to decide for yourself whether you return the watch, and buy something else, or whether you wait (possibly a few weeks) till Garmin fixes it, or whether you prefer spending 10 minutes of your time in trying to fix it yourself instantly.
  • KEY_CALIBRATION.BIN
    Apparently it's sufficient to create a blank file with this name and use that. I haven't done that.
    Now that I know the watch will shutdown in cold water what I do before a swim is get in the water and let the watch do its shutdown thing then restart it and swim. Once I've done that the watch works as expected for the hour or so I'm swimming. It's not ideal but it's also not stopping me from swimming.
    At no time while I've been communicating with Garmin have they suggested it's a hardware problem but that's not to say there might be a problem with some watches. What I do understand is that a fix will be provided shortly.
    And no, before anyone asks I do not have any idea of a timeframe for 'shortly'. If you are having this problem - and not simply bumping your gums - then contact Garmin Support directly. The more contact from people genuinely experiencing this issue, the more likely the fix will be provided quickly.
  • This brings up an important implication.
    The Fenix 8 has a "water rating of 4 ATM Dive (EN 13319)²," where ² indicates "Designed to comply with CSN EN 13319."
    CSN EN 13319 specifies requirements for attributes such as accuracy, pressure resistance, robustness, safety, and operating temperature ranges.
    Aside from operating temperature ranges—the specification requires operation from 0°C to 40°C—and robustness, safety features and also controls should function properly - imho without the need for calibration. To my knowledge, the regulations do not allow for easy recalibration of mandatory safety functions - like depth sensor.
    This leads me to question: How did the Fenix 8 achieve certification, or could there be concerns about assembly tolerances?
    Just my thoughts...
    Ps: sorry, my fault. Non native speaker here XD "designed to comply with" vs "certified according to"
  • Even if they don't say "certified according to," they would not be allowed to sell this as a dive computer if it were not compliant with that. Let's wait a bit and see if they resolve the issue, but if they don't, I suppose Garmin should be put in the spotlight for this.
  • It's already getting grip in the news media www.notebookcheck.net/Garmin-Fenix-8-users-flag-important-issue-with-dive-watch.893258.0.html
    PS: also had a similar local news post suggested in my google news feed
  • Confirmed. The same here (ca. 7 C) and Fenix 8 Amoled 47 mm rebooted after a while.
  • Would be interesting to see if this is a general problem with cold temperature or water specific. Maybe someone can start an activity and put the watch into the fridge for some time?
  • Already checked. I left Fenix 8 in a freezer for 15 min and nothing happend - worked fine.
  • It’s cold water and something to do with the touch screen.
