I have a corrupt file on my fenix 5s and can't seen to fix it with the installers--maybe because I'm on a mac? Garmin support is ghosting me, and I can no longer sync any files because this one seems to block them. Any ideas>?
Before you delete it forever, zip then post it here to see if someone can repair it for you.
No. It's zero bytes. There was a similar thread regarding deleting a fit file using a Mac. This might help guide you in the right direction.
How To Delete .FIT File From Previous Owner - fēnix 6 Series…
Thanks--looks as it a reset is in order. I appreciate your help @seilogramp
Try to rename corrupted file then maybe you can delete it - this worked for me in some cases on Windows PC.
It says the file is empty, so cannot be uploaded. :-( But thank you!
Thanks--worth a shot, but it didn't work.
E7O53227.FIT (1).zipLet's see if this works . .. .thanks!
How To Delete .FIT File From Previous Owner - fēnix 6 Series - Wearables - Garmin Forums
Alternatively, you could factory reset the watch.
