My Fenix 6X Pro has a white dot on the screen that will not go away. As if a part of the screen does not function and blanks out info. See picture, dot on the bottom of screen.
Probably a swollen battery pushing against the display. Contact Garmin Support and ask for a replacement if under warranty. If not ask what would the repair cost.
If it is a swollen battery, stop using the device and replace the battery.
However it could be a 'mura' spot. It has been reported quite a few times: https://forums.garmin.com/outdoor-recreation/outdoor-recreation/f/fenix-6-series/278301/white-spots-on-whatch
That is only fixed by swapping out the display, which is an expensive part, and contacting Garmin for replacement options is better.
