Garmin is not recognizing properly there might be a hardware problem with the fenix 6 solar. They are not exchanging faulty matches out of warranty when the solar charging stops working without any advice and out from the blue. So, Garmin, here is a list of people complaining about an expensive feature of your watch that stopped working suddenly... Do something!!!
Fenix 6x Pro Solar - solar charging indication not workingGarminhttps://forums.garmin.com › fenix...
Solar Charge is not working - fēnix 6 series - WearablesGarminhttps://forums.garmin.com › solar...
Solar Charging problems.. - fēnix 6 series - WearablesGarminhttps://forums.garmin.com › solar...
Fenix 6X Pro Solar won't charge from direct sunlightGarminhttps://forums.garmin.com › fenix...
My Garmin Fenix 6x pro solar is not charging from solar ...Reddithttps://www.reddit.com › comments
Garmin fenix 6 pro solar does not react when exposed to the ...
Garmin fenix 6 Pro Solar solar charging does not workYouTubehttps://www.youtube.com › watch
So, Garmin, you should probably accept a problem with a really expensive and not that old device. Find out what is happening (pro happening sooner or later to the most expensive series of fenix 7) and give us a solution!!! Doesn't make sense that we people are trusting for years in your devices and you'e letting us down like this...
I'm also starting a list of affected devices, if your Garmin fenix 6 Solar stopped working by any means, then fill in those details on a reply. This is the second unit with the same problem so far...
Device: Garmin fenix
Series:
Warranty: Yes / No
Solar Problem:
Purchase date:
Comments:
