Good morning,
1. How can I see my current GPS coordinates on the watch?
2. Can coordinates be displayed on my map?
It would be great if someone could help. I called the customer support line but they couldn't advice properly.
Many thanks
Good morning,
Many thanks
2. If you save your location through the first step, then you could see it on the map
https://www.youtube.com/watch?v=x0eM2oRp0Ss (sorry it's in french)
Good !
jim_m_58 is good developer with many post, comment on the forum.
Direct link to its app : https://apps.garmin.com/fr-FR/apps/e5e38814-0a10-4151-b677-9c616a0c5f05#0
Connect IQ is also available in the Playstore
So there are two ways.
1. the way via the web version of Connect. Use the link from socursu, download the widget and synchronize the Fenix.
2. the way via the…
Hi,
1. from watchface or from an activity
Go to "Controls", 2sec press Light button (upper left)
Then search for the red inverted water drop "Save Location"
Start it outdoor
And voilà
Or you can download the UR Here widget from connect IQ.
Thank you so much!
Could you please tell me how to do it? Where can I download the UR widget from Connect IQ? Thanks
Good !
2. the way via the app. In principle, the same procedure, but the desired widget must first be entered in the search field. Then you can install it on the clock.
If you only want to see where you are on the map, you don't need to download a widget.
Just select the "Activity" MAP with the "Start" button and launch it. As soon as the GPS reception is green, you can see where you are on the MAP.
Thank you, I've done it. Very useful!
I've noticed that. The only problem is that it doesn't show the coordinates on the map itself.
