Good morning,
1. How can I see my current GPS coordinates on the watch?
2. Can coordinates be displayed on my map?
It would be great if someone could help. I called the customer support line but they couldn't advice properly.
Many thanks
Good morning,
Many thanks
2. If you save your location through the first step, then you could see it on the map
https://www.youtube.com/watch?v=x0eM2oRp0Ss (sorry it's in french)
Good !
jim_m_58 is good developer with many post, comment on the forum.
Direct link to its app : https://apps.garmin.com/fr-FR/apps/e5e38814-0a10-4151-b677-9c616a0c5f05#0
Connect IQ is also available in the Playstore
So there are two ways.
1. the way via the web version of Connect. Use the link from socursu, download the widget and synchronize the Fenix.
2. the way via the…
how do you mean, on the card itself ?
Here you can see the map and position. That's all the widget does.
The only problem is that it doesn't show the coordinates on the map itself.
The "problem" with a third-party app from the store is always that the respective developer (mostly private individuals) have to adapt the app to new firmware again and again. If the developer no longer supports the app, it may no longer work as soon as a new firmware is released.
That is the reason why I rely on internal solutions as much as possible. It would be stupid to rely on an app and then realize in the mountains that it no longer works.
Hi,
I share the same habit with you.
this is why in the firsts exchange i provide an existing solution on the watch.
I wasn't referring to the app. I was referring to the map (on the watch). The app is great.
The app is great.
Then nothing would be visible on the map except coordinates.
When using the U R widget before, I'd see the coordinates (not a map). Now whenever I open the widget, I can see the map but not the coordinates. Have I done something wrong?
the location coordinates should be at the bottom of the screen
