I have received the 24.00 update, but my sensor HUB still is version 20.04 not the one stated in the frimware release notice.
Updated - engineering has confirmed the Sensor Hub update is not pushed out at the same time as the v24.00 software update. The Sensor Hub v22.09 update will arrive on its own but it could be towards the…
Thank you!!! I spoke with engineering and was advised, everyone that has not received the Sensor Hub yet, it should arrive today. Please sync again. (I suspect that means we found something but the good…
Sensor Hub update could be pushed without System update, no problem for that. The files are different and Garmin Express store these files in different folders.
Version 24 is now fully released, come on Garmin, fix the omission asap and push the sensor hub update
Hello Garmin devs? are you still alive?
Here we are on Tuesday of the following week with V24.00 having had been pushed WELL into 100%, days ago. Where are the sensor and other component updates??
Please plug your watch directly into your computer USB port and do a sync using Garmin Express. When you are done, unplug your watch and go to your System > About menu. Ensure you see v24.00. Then go down 5 times.
What versions do you see for all 7 Sensor Hub software versions? Thank you.
Chris thanks for writing.
Screenshots below:
Garmin - Chris The only way i was able to update sensor hub, whr and bmx was to use the gcd file from 22.73 alpha. I think it told me that Bluetooth got updated too. Everything is good now. GE never prompted me for sensor hub and i am practically sure i am running the latest version of express
Thank you!!! I spoke with engineering and was advised, everyone that has not received the Sensor Hub yet, it should arrive today. Please sync again. (I suspect that means we found something but the good news is everyone should receive it now that has not.)
Thank you to everyone for watching for it and bringing it to our attention.
ANT/BLE was already updated many months ago, no reason for this module to be updated :-)
I definitly suspected there was a hiccup with this release. Thanks a lot for the update.
The update came up as soon as you posted! :)
