I have received the 24.00 update, but my sensor HUB still is version 20.04 not the one stated in the frimware release notice.
Updated - engineering has confirmed the Sensor Hub update is not pushed out at the same time as the v24.00 software update. The Sensor Hub v22.09 update will arrive on its own but it could be towards the…
Thank you!!! I spoke with engineering and was advised, everyone that has not received the Sensor Hub yet, it should arrive today. Please sync again. (I suspect that means we found something but the good…
Ditto. Not impressed by constantly being messed about by defective, incomplete software. No, I do not want to mess about with extracting/deleting/messing about withfiles from beta software. Can I just download a firmware via Garmin Express (the train that doesn't get anywhere, over and over again) that actually has the content it is supposed to have. Please. My first ever rant here. Garmin Fenix 6s Pro. Firmware 24.00, supposedly.
Hi Chris,
Is it possible to have an updated feedback ?
We saw many post about Snesor Hub (BMX/WHR) not updated even after 24.00 fully released.
Thanks
I understand your frustration, waiting for Garmin for an explanation and good solution like OTA (GC) or Garmin Express re-release of the update.
We encountered the same issue during Alpha Phase, because of a faulty Sensor Hub.
- first 20.09 instead of 22.09
- Second 22.09 (or 20.09) i can't remember, without BMX/WHR updates for F6/F6Pro
The Sensor Hub 22.09 from 23.73 is the final and corrected version.
forums.garmin.com/.../alpha-version-23-73
And why to download from version 23.73 and not from 23.74? or higher? And is it possible to go back to the concentrator version from the 23.10 20.04 firmware? If so, how because it seems to me that this new version 22.09 works worse barometerBecause the Sensor Hub file is the same, and you will not install the Alpha 23.7x System file to your watch.
But because the 23.74 seems to be corrupt too as described and following the exchange here.
No change for me regarding barometer with this version.
I just mention that 100% has been reached by now.
Thanks, but I prefer not to play with the Beta files, I dont want to mess nothing, I am not so skilled to do that! Anyway, thanks for your Excel Changelog post, thanks to it, I now that something was wrong. Hope somebody from Garmin give us additional info.
Thanks
I am in the same boat. Never got the 22.09 update and ge does not offer it. I did get the sensor hub file update from the 22.73 alpha archive and dropped it into the remotesw folder. Everything got updated. I think they may release a 24.01 that will push the update but getting the file from the alpha worked fine.
Updated - engineering has confirmed the Sensor Hub update is not pushed out at the same time as the v24.00 software update. The Sensor Hub v22.09 update will arrive on its own but it could be towards the end of the software update release process or even after the software release reaches 100%.
Pierrotsc, I think Chris from Garmin communicated it fairly clearly 6 days ago what would happen.
I think Garmin - Chris only knows that engineering tells him. I am going to speculate here but if GE sees that you have 24.00, it is not going to update anything. i do not think it checks for sensor hub version. I have to assume that they fixed the missing download after users realized that sensor hub was not updated. So if like me you did not get 22.09 the first time, the only way would be to install manually from 22.73 alpha. it worked fine with me or wait for the next public release.
