My VO2max has now been stuck to 62 since July, it doesn't move at all no matter how well (or bad) my running goes. The performance condition set during the runs may be anything between +10...-5, with averages well above 0 or under 0. The VO2max still won't change.
My training status has been "Maintaining" since August. The acute load has varied from ~500 to above 1000, it typically stays in the optimal range. Doesn't change the training status either.
The race prediction time corrected with the v23.10 also stay within 2 s (at least for the 5k). They now seem realistic and this is a huge improvement after the v23.00. I don't know if the race prediction times should move a little like they used to (I don't mean like 5min for 5k like they did with v23.00)?
The target pace and heart rate of the running suggestions have been way off since the v23.10. As an example, for a base running exercise my target pace is now 5:00 min/km and HR 140bpm. These values don't match at all. 5:00min/km is a recovery pace for me, my average HR for 5k a 5:00min/km is under 125bpm. The fast limit of the pace is 4:31 min/km, I can't remember the low limit. HR range is 126 to 151. Now if I run 10k at 4:31min/km (fast limit), my average HR is around 130. If I run at average HR 151 (upper limit) I go under 4:00min/km. In the earlier sw-versions these (target pace and HR) used to be close to each other and realistic. The target pace and HR haven't moved since I got v23.10, they are stuck as well. Due to this, the running suggestions are of no value to me anymore. They also don't stand for the load focus either.
