Hello Guys, it has been a few days I'm having extra vibration with awful sounds from my garmin fenix device! Does anyone know the source of issue?
When your internal vibrating mechanism fails, it will sound like an angry bumble bee is now stuck inside your watch and rattling around. If this happens to your watch, please reach out to your regional…
I am sorry you had an issue with your watch. When you warranty replace a Fenix watch, you will continue your original warranty unless it is ending in less than 90-days. If you are less than 90-days from…
Same issue here too. Going to open an RMA as soon as possible
Got the same problem a few weeks back, did an rma case to Garmin and got it exchange
Had the same prob after only 4 months and got it exchanged. Unfortunately seems to be quite common. Good luck!
what is it supposed to sound like. i wake up with only vibrations but i have sound with a timer. it makes a sound and i assume it is fine but now i wonder.
When your internal vibrating mechanism fails, it will sound like an angry bumble bee is now stuck inside your watch and rattling around. If this happens to your watch, please reach out to your regional Outdoor Product Support.
Could I get a sound file to hear a normal sound when I finish my timer ? I am not sure if my sound is normal. In the morning I only use vibration.
Please feel free to highlight my name and send me a private message to listen to what your watch sounds like. I will be happy to compare it.
I did not ask for a defective. I asked for a normal sound to compare. If mine does not sound the same then I will know it is defective.
i will try to capture the sound of my watch and send it to you.
After close to 2 years of flawless operation, this just started to happen to my Fenix 6 Sapphire. Unfortunately, Garmin wants $190 to refurbish the watch. I might just have to wait until the next Fenix release
If it only makes the sound when waking you up please check if the options of the alarm include sound. You can have vibrations only or vibration and sound.
