All has been good and recently I get this error? I deleted my network and tried to reconnect via the watch, garmin express on computer and through the ios app.
any ideas??
Workaround to Receive HRV to Your Garmin Connect:
HRV will sync through Bluetooth using the Connect Mobile APP or through using Garmin Express on a computer.
@Trener39 @NB @Former Member
This morning, a while after waking, but without opening my GCM app I tried syncing with WiFi. It started syncing, but failed. I tried a second time and it failed again. Then I opened GCM…
Maybe the remedy of the bug does not lie in changing something in the watch sw, but in the processes running on the remore server(s). If so then it is reasonable why the pattern of "18:00 CET" has changed. But it is just another idea without any evidence.
Contact UK Product Support in your region
I guess it may be a typo and it was meant either "Contact Product Support in your region" or "Contact Outdoor Product Support in your region". Anyway no offence meant.
Thank you for catching it. Corrected.
You make a valid point. What complicates a sync issue is the bug can be the Garmin Connect Mobile APP being updated, Garmin Connect web being updated and then add to that the watch side updates.
Thanks for confirming that there is some sort of logics behind the failed sync pattern, even if it is hopeless for us users to deduct what’s happening in fact.
Btw I myself gave higher probability to the change in the server processes than to the Taipei-theory. ;-)
