Clearly the guided test isn't going to work for me :) Fenix 6, using Garmin strap. Strap works fine to autodetect FTP with cycling/power meters. I've had a fenix for 5 years, and went back through all data to check max HR - for running, my max was 185 that I hit once, and I had one outlier at 205 while I was pregnant...I have to believe that was some sort of read error because I haven't even approached that any other time in 5 years. The highest I have been able to eek out on the LTHR guided test is 172. Cycling is a bit lower (169 at end of 20 min FTP.) So, I set maxHR at 177 as kind of a medium.
Anyway, thoughts on maxHR settings, and also what kind of a run do I need to structure for optimal chance at LTHR autodetect? Thanks!
