Hi
my solar charging is not working anymore since one week on my fenix 6x pro solar.
is it a hardware failure ?
i did two hard reset, still not working.
All days are sunny days. Last time it worked was on July 6.
Hi
The only thing I can add is that I own a Fenix 6X Pro Solar. I do all the updates. I have never ran into the issue. Same goes for teammates
I am sorry if you are experiencing an issue with the solar charging…
If basic troubleshooting does not work to resolve a solar charging issue, then that Fenix 6 series solar watch has a hardware issue and must be returned to vendor, warranty exchanged through…
To be clear on any solar charging issue:
If your solar charging has stopped working, and if neither the Soft Reset (hold down your top left button until your watch shuts off, then let go) or the Full …
On 13th there are also some little peaks visible. But your battery was < 100%, I guess? If two hard resets did not work, I think it is a hardware issue, too. I would contact customer support.
Have you added something to the screen covering the outer small ring of the display? The Small spikes let me think that the outer ring (100% solar) does not work but the display (10% solar) is working ok.
Former MemberNo i did nothing
Most probably hardware issue. I had the same issue and watch got replaced.
I have the same problem
garmin France don’t want to change the watch
they say I have to wait for a new software
Perhaps they know (but don’t say) that is a sw issue...
Yes
but for the moment the solar charging is not working
i have to wait ( I don’t’ have any solution)
If soft-/master rest didn’t bring the solar functionality back to life and it is no general problem (it isn’t), I would guess it is an hardware issue...
Yes it’s possible
my other problem is that for ask an exchange they want the copy of the bill and I be baught the watch on eBay so I don’t have bill
it’s also because I hope it’s a sw problem and a new version will correct the problem
