Fenix 6 Pro - Wifi Issues (FW: 8.10)
I don't seem to be able to connect to my home Wifi using my Fenix 6 PRO. The connection test fails, and the sync returns error 0105.
My connection has a WPA2-PSK-CCMP password and is a 2.4GHZ. I only seem to be able to connect to open networks. Anyone else has the same issue?
I have also tried to setup a hotspot with my phone with the same result.
This seems to be a software issue.
  • I get the similar issue, password fails despite being correct
  • I think everyone here has the same problem. Unfortunately, this is not fixed. I will not connect to various routers at home, or to a router at work, or to a hotspot on a mobile phone ...
    0 Former Member over 5 years ago in reply to marexor
    Same. This seems to work only on open networks. As soon as I enable a password it doesn't work anymore. However messing with my router settings I was able to connect at least two times (over like a thousand tries) with the password on, but not reliably.
  • Just checked and mine is connecting fine to my WiFi. There’s been some quite extensive discussions about this so if you haven’t already done so you might want to have a read of some of them. Couple of pointers:
    SSID must be open not hidden.
    If you have a network that broadcasts on both 5GHz and 2.4GHz with the same name create a separate one for the 2.4GHz and make sure you are using that.
    If I want to create a hotspot using my iPhone I have to make sure it is connecting to my 2.4GHz network.
    Do contact Garmin Support as it is of course possible there might be a problem with your watch but invariably it’s come down to settings on individual routers.
    0 Former Member over 5 years ago in reply to Dr Phil
    Thanks for the tip! I have tried all of them: I have a separate connection for 5Ghz and 2.4Ghz, SSID is open and I don't think that it's an hardware issue since it works on open networks... Are you on 8.10?
  • I am currently on 8.78 but I have had no issues on any version.
    0 Former Member over 5 years ago in reply to Matt_Barrett
    This also happens to me using my phone as hotspot! Very very weird.
    After much testing, I've found the solution -- here's hoping I save someone else time and much annoyance:
    Firstly, make sure you're connecting only to 2.4Ghz as it doesn't support 5 ...  make sure you force this as some newer routers have a "smart connect mode" and may be actively trying to connect you to 5Gz.
    And here's the kicker now:  It only accepts password lengths of 8 characters.   Yup, you read right.  Didn't work for me with completely open, and with my regular passwords of 24 characters .. kept telling me incorrect password even though I knew it was right.
    Got me thinking ... WPA enforces 8 .. but what if coding was wrong (big surprise) and they actually accepted MAX 8 characters .. Well, that seems to be it.  Didn't test if < 8 works .. but anyway .. have fun.
    Cheers
    p.s: obviously 8 character passwords suck .. so I activated my previously de-activated GUEST network and made this one just for the Fenix (garmin) exclusively.  Only 8 characters max but who cares on guest wifi network, not much exposed.
  • Weird - I have a 15 character password but it's in the three word format - you using non-alphanumerics?
