Loosing connection to my jabra 65t elite active when I turn on a workout like running. Anyone with same problem
I downloaded Spotify offline list and it works fine until I start tracking a workout
Hi the same problem with samsung buds, i placed fenix on the right wrist it works without a problem.Also I tray with galaxy watch, it works better than Garmin. I thing Garmin fix this ***!
If Samsung has their BT in the right earbud and you choose to wear your watch on your left wrist, how is Garmin supposed to fix that for you and why do you think Garmin is responsible?
I think this is software problems, in last update there was bluetooth stability, but seems that was not enough.I am not choosing i am all the time watch wearing on the left wrist. And I don't wanna change something. And at least, I don't like running with headphones, for me its not a big different, but when you pay 600€ for a watch you want the best quality.
The answer and solution to your problem is in this thread: https://forums.garmin.com/outdoor-recreation/outdoor-recreation/f/fenix-6-series/235015/headphone-disconnects-after-starting-activity/1119175#1119175
G
With Galaxy buds, if you wear the watch on the left wrist, as I do, then remove only the left bud from the case, close the lid and let the watch connect to the left bud. Now remove the right bud and that will join the party. With left bud connected first your connection should be more stable.
Unfortunately the head and body are quite effective at blocking the signal. Indoors the signal may bounce and still work. Outdoors there may be nothing suitable from which to bounce so the signal breaks up.
Yeah no it's not.
With Garmin watch and Jabra buds it's a simple hardware issue. Watch on right wrist solves it.
Exactly, in this case just a one solve, wear watch on the right wrist. I try with two watches, on the left wrist, at wrist with galaxy, without gps works perfect, than switch to run mode, watch searching gps, sound cutting, found gps, still cutting sound in a 10 sec everything goes wright run about more 1-2 min. Without problems. Than changed watch to the Garmin fenix 6s pro. On the left wrist, music on played well, walking, have no problems sometimes i heard sound cutting, but at list was good. Start the run, music cuts a special when run on the field. Problem gone when placed watch to the right wrist, as Simon wrote( thanks Simon).But still this is not solution, i want wear my watch on left wrist, and problem is with Garmins software not with hardware.
This is briliant I was losing my mind on how to get this damn thing to work without switching watch wrists
Thank you!
