How much battery % / hour fenix is using when is connected to a smartphone via bluetooth?
On F6 Battery full
21 days without BT 0,20% /h
14 days with BT 0,30% /h
-> 30% more consumption with BT.
Ha, it's a good question. Excluding battery drain during activities, my watch has regularly shown depletion rate around 0.5%/hr. I think the days projection is a steady state estimate, meaning at that…
i think wifi is off all the while besides anything to upload right?
Go into the Power Manager under settings, Battery Saver. Select Edit and make the changes you want in there. You can then set it to come on at the times you have set for sleeping..
