How to change the colour of 'navigation/course follow line' with your own map theme!
As I've posted in this thread, by the navigation line in my watch changed sometime in the middle of Sept. to a much thinner one that I've trouble seeing with most of my maps: https://forums.garmin.com/outdoor-recreation/outdoor-recreation/f/fenix-6-series/194034/how-to-change-the-colour-of-the-navigation-line
Contacted support, but they didn't have an answer.
I started to test what possibilities with the map theme files and found out that this style field="MPM_ACTV_CRS_CLR" is used for the navigation line.
If you create different map theme files with different colours, you can even change the colour while running depending on the map background.
Create a text file and save with extension 'kmtf' to the map theme folder on watch.
This text give you a dark green line with dark green borders.
<?xml version="1.0" encoding="UTF-8"?>
<garmin_map_theme>
	<metadata>
		<title>DarkGreen</title>
		<description>DarkGreen</description>
	</metadata>
	<stylelist>
		<style field="MPM_ACTV_CRS_CLR">
			<color>
				<primary day="#ff006400" night="#ff006400"/>
				<secondary day="#ff006400" night="#ff006400"/>
			</color>
		</style>
	</stylelist>
</garmin_map_theme>
Great color code page: http://www.farb-tabelle.de/en/table-of-color.htm
Some examples: Blue, green, magenta and the last-right one are red with blue borders.
The two bottom-left is the thin original that shows up if no theme is used.
