Jabra elite 65t & fenix 6x
Hi, since software version 4.20 I'm not able to connect the jabra elite 65t with the fenix 6x. When pairing, it keeps on searching the headphones. Sometimes it finds them, but connection is immediately disabled. This was not the case with the out-of-the- box software version 3.0... The jabra's work perfectly with other devices as phone, tv,....
Anyone else having this problem?
Top Replies
All Replies
  • No problem for me, removed them and paired them again without any problems. All controls works from both watch and right/left earbud.
  • I have this exact set up (F6x 4.20fw+ Jabra Elite 65t), myself, and I haven't had any problems.
    Good luck!
  • Update: I could not get this fixed during a run in the middle of Brussels. I did receive bluetooth pairing suggestions from other persons which were running/walking at my garmin. At home when shutting off nearby bluetooth devices it worked... Seems to be an interference problem when other Bluetooth sources are in range...
  • That's very interesting. I honestly don't know that much about what goes into Bluetooth pairing - but now that I think about it, I did have some challenges with the initial setup between my Elite 65's and F6x, which happened when I got excited and tried to do the initial set up in a crowded shopping center. Couldn't get them to work, put them in my pocket, went home, started the pairing over again, and everything worked perfectly. No problems since.
    0 Former Member over 5 years ago
    Bonjour Flemke,
    As tu réglé ton problème ? car j'ai le même souci que toi : mes écouteurs JABRA elite 65T se connectent très bien avec ma fenix 6. Je peux écouter de la musique sans soucis. En revanche, dès que je lance une activité (peu importe le type d’activité, course, vélo....), alors la connexion avec les écouteurs est systématiquement coupée et les écouteurs cherchent constamment à se reconnecter ...sans succès.
    C'est juste insupportable, il m'est impossible de connecter les écouteurs lorsqu'une activé est lancée (avec ou sas musique d'ailleurs). Pour moi aussi, les écouteurs fonctionnent très bien avec d'autres appareils que la fenix....
    J'ai appelé le SAV GARMIN.... réponse : "réinitialiser les écouteurs et le problème sera réglé ".... ben non, cela ne change pas !
    J'ai appelé le SAV JABRA ... réponse : "c'est le capteur de pas des écouteurs qui doit faire interférence... il fait désactivé le suivi d'activité sur la Fenix... la aussi, je l'ai fait, mais aucune amélioration. toujours impossible de connecter mes écouteurs à ma Fenix 6 lorsque je lance une activité ! un comble pour une montre de connectée de sport !
    Est-ce que qq'un peut m'aider ?
    Merci,
  • Well I can't  speak French but to get the jabra elite 65t to connect you have to first delete them from the watch and reconnect (buds in pairing mode). Need to do this every time.  PITA, but I think it's a fault of the buds.
  • Former Member &  sounds like your issue is that your Jabras are paired to your watch as a footpod. This is the reason for the audio dropouts
    "Go to the Sensors menu, pair the Jabra footpod, then when it's paired set its status to off. In that case when you start the Run application it won't search for the Jabra footpod and the audio won't disconnect either."
    This thread below was made a sticky on the Fenix 6 forum.
    Bluetooth and headphones. See post marked as answer by crt_hun.
    0 Former Member over 5 years ago in reply to Former Member
    Bonjour Fabrice,
    J'ai rencontré le même souci lors du passage à la version 6.10, c'était dû au capteur d'accélération intégré aux Jabra (ce sont les Active 65t que je possède); une fois désactivé dans les paramètres c'était ok, sinon les écouteurs se désactivaient dès que je lançais une activité.
