Garmin Forums
Garmin Forums
  • Site
  • User
  • Site
  • Search
  • User
  • Apps & Software
  • Outdoor Recreation
  • Sports & Fitness
  • Pilots
  • Developer
  • Beta Program
  • German Forum
  • More
  • Cancel
Wearables
Wearables
fēnix 6 Series —
    • New
    Related
    Options
    • RSS
    • More
    • Cancel
    Duffyanneal
    Duffyanneal over 6 years ago
    • Sign in to reply
    • Cancel
    Top Replies
    • gaijin
      gaijin over 6 years ago +2 suggested
      If you were charging the watch in the sun off your wrist, then likely the display got too hot.  Dark spots like the one you show are typical on other solar powered watches that are left in the sun and get…
    All Replies
    • C.sco
      0 C.sco over 6 years ago
      Interesting... so the black spot goes away when you remove it from the sunlight for a while?
      I'd say, if it bothers you then I'd exchange it for another one.
      • Cancel
      • Up -1 Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • bluefish
      0 bluefish over 6 years ago
      Put off your screen protector. This may help.
      • Cancel
      • Up -1 Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • C.sco
      This is the first report I've seen of a dark spot on the screen (there have been some reports of darkly-lit spots with the backlkight on, but I think that's different, because your dark spot appears without the backlight illuminated).
      It would probably bother me enough to send it back for a replacement.
      Keep in mind that this solar display thing is brand new technology, as far as I know this is the first watch ever to use it, and it's definitely the first Garmin to use it. So there are bound to be some issues with some of them. I think this watch is a good candidate for a replacement.
      • Cancel
      • Up -1 Down
      • Sign in to reply
      • Verify Answer
      • Cancel
      0 Former Member over 6 years ago in reply to C.sco
      Only sorta related but I've had a Citizen watched that's solar powered only for several few years now.  It's not a smart watch so it doesn't use much power, just average normal while collar daily exposure to inside or sunlight was enough to keep it running without any issues.   Only point to that is it's not necessarily new technology although Garmin may be using newer versions of the technology (I'd be surprised if they weren't).
      • Cancel
      • Up 0 Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • C.sco
      0 C.sco over 6 years ago in reply to Former Member
      Is it a solar panel behind an LCD screen?
      • Cancel
      • Up -1 Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • gaijin
      0 gaijin over 6 years ago
      If you were charging the watch in the sun off your wrist, then likely the display got too hot.  Dark spots like the one you show are typical on other solar powered watches that are left in the sun and get too hot.  Charging while on your wrist prevents the watch from getting too hot.  As long as you charge the watch in the sun by itself, even an exchanged watch will likely exhibit the same issue.  Always charge in the sun while wearing the watch to prevent this overheating of the watch.  Unless severely overheated, the watch should return to normal when it cools down.
      HTH
      • Cancel
      • Up +2 Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Volker
      0 Volker over 6 years ago in reply to gaijin
      If the watch get to hot, the solar charging is stopped automatically and a red thermometer sign is displayed on the display. Have done several solar chargings with laying the watch in direct sunlight for testing the solar functionality, but never saw a black spot on the display.
      www8.garmin.com/.../GUID-E72F3619-D372-44BE-BEBC-348065CEAC07.html
      • Cancel
      • Up -1 Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Duffyanneal
      0 Duffyanneal over 6 years ago in reply to gaijin
      • Cancel
      • Up 0 Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • gaijin
      +1 gaijin over 6 years ago in reply to Duffyanneal
      Understood.  I wasn't sure whether you were wearing the watch while charging.  If your display is darkening while you are wearing it, I would consider that cause for concern.  I don't know if that would be the case for all 6x PRO Solar watches, but if it were me, I'd strongly consider swapping your watch for another one - couldn't hurt.  Good luck.
      HTH
      • Cancel
      • Up 0 Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • rjgunn61
      0 rjgunn61 over 6 years ago
      My 6x does the same
      • Cancel
      • Up 0 Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    Copyright © 1996-2025 Garmin Ltd. or its subsidiaries
    • Site Map
    • Terms of Use
    • Privacy
    • Security
