As the title. I have no theme set. Happens regardless of the map I try and use. If I switch to ‘popularity’ then then the background is white as I’d expect. Anyone else seeing this?
Jesus christ people... I get it, there are people from all over the world on this forum... but when a thread is entirely made of english-speaking posts, why would you write a post in some different language…
Doing the suggested reset seems to have worked. I’ll flag this as an answer although don’t really think it’s a good one as we shouldn’t have to do factory resets of the watch!
I…
I’ve seen the black background on my watch too. I assumed it was night mode as it seems to have a white background during the day and black at night.
I've seen this too, but during the day. I restarted the watch, and it seems to be ok now. I suspect that sunset/sunrise time got screwed up.
That would make sense, don’t understand where that data comes from though. The stock watch faces do seem to have the right data for sunrise/set, and regardless of time of day the maps still have a black background.
I’ve tried a soft reset, really want to avoid a hard reset...
I have this issue as well. No theme selected, but the map background is dark grey (not black). This is not affected by time of day, it is always grey. I have to switch the map theme to high contract to get the white background back. Very annoying.
Anyone else having these problems?
The time on my watch is correct and I use GPS for the runs themselves (and map navigation) so not sure that’s the issue...
Mine too had GPS fix. However, it was a day or two after I flew from Hong Kong to Ireland. Its possible that sunset/sunrise time got stuck on HK time.
Had the same. I think to get the white background, you have to select 'high contrast' in the map settings.
