D2 Charlie Altimeter / Vertical Speed <-> Aviation Units BUG
Running firmware 4.00 (latest at the time of writing), the D2 Charlie still suffers from the following nuisance/bug:
Even though Aviation Units are enabled (e.g. elevation in *feets*):
- altimeter (widget) *calibration* is still shown in the "system" units (e.g. *meters*)
- FLY (app) *vertical* speed is based on "system" elevation units (e.g. *meters/minute*)
This makes:
- the altimeter (widget) a *nuisance* to calibrate (e.g. based on current airport known reference altitude)
- the FLY (app) *dangerous* (since meters/minute are close enough to feets/minute to be easily mistaken and the discrepancy not obvious)
  • This issue has already been added to the bug list by dbrobert, see https://forums.garmin.com/forum/on-the-trail/wrist-worn/d2-series/1312355-d2-charlie-version-4-00
    I got a new D2C last week. I am having an issue with the accuracy of the altimeter. I noticed that the Altimeter is approximately 250 feet off when calibrated using the barometric pressure obtained from the nearest METAR. I was at the airport the other day and I can confirm this issue. I understand that I can calibrate it manually but I just wanted to see if anyone else has experienced this issue.
    Yes. And it has been here right from the beginning (at least v2.90 as far as I can tell). It'd be nice if acknowledged by Garmin itself!
    Same here. Enable the Barometer widget and look at its calibration settings: you can set both the altimeter and the corresponding barometric pressure (QNH ?), thus "calibrating the instrumental error". Since then, the Altimeter - once calibrated with the actual altitude - has given me barometric pressure that match the current QNH quite closely (I expect calibrating it the other way around, thanks to METAR, ought to work better too).
    Garmin again:
    That being said, it'd be nice if the Altimeter could also be calibrated manually (not though METARs) using a known barometric pressure (QNH).
    (rant)
    It is appears the devs of the D2 know nothing of aviation and let pass the most glaring problems/inconsistencies.
    Sad given with the price of the gadget...
    (/rant)
  • I have a D2 Charlie now and have been working through the reported bug list and compiling my own list, including the issues with Garmin Pilot and with the auto-import feature of the FlyGarmin logbook. I've already reported a few additional issues, but I will make sure I put the full list together after the next release (overdue now) and send it to the D2 team.
    Cheers,
    Douglas
  • The altimeter does not seem to catch-up with the changing elevation quickly enough...see my recent flight: https://connect.garmin.com/modern/activity/2766486656
    The airport elevation is roughly 1000 feet. I had the autofly mode enabled (500 fpm) which started recording after some distance after I took off. I was at least 1500 feet by that time it started recording..but it is showing as 1053 feet. Same thing when I landed...it is showing the altimeter as roughly 2000 feet when I touched down... I noticed some similar conversation going on in the fenix 5X forums as well..hopefully, garmin will fix it when they fix the similar issue with the 5x.
    I think I might have the explanation for this behavior:
    Go to the *Barometer Widget* settings and verify the "Watch Mode" is set to "Altimeter". If it is set to "Auto" (the default, if I recall correctly), the watch attempts to work both as an altimeter and a barometer (...): if pressure variations are small enough, they are considered barometric pressure change; if pressure variations are fast enough, then they are considered altitude-pressure change. Of course, as an aviator watch, we want to make sure it behaves as an altimeter only, and not some weird mix of pressure-related instruments :-/
  • I think I might have the explanation for this behavior:
    Thank you. I will give that a try. Did this work for you? One would assume that Garmin already incorporated this when FLY app is started.
    This bug is also here for Fenix 5X that i owned (and i suppose 5) : https://forums.garmin.com/forum/on-the-trail/wrist-worn/fenix-5x/1326484-altimeter-is-wrong-on-fast-decent , and Fenix 5 Plus that i own: https://forums.garmin.com/forum/on-the-trail/wrist-worn/fenix-5-5s-plus/1366374-here-we-go-again-altimeter-is-wrong-on-fast-ascent , i'm reporting this bug since months but nothing... please report this bug you too...
  • Thank you renton82. I sent an email to Garmin Aviation support. I will post if I hear anything from them. It looks like the issue is widespread.
  • Firmware updated to 4.20 (double-checked with Garmin Express and rebooted the watch twice): both issues reported in original post are still present (despite changelog mentioning a fix in this respect to the Altimeter widget).
