Complete
Not a bug.
Weather.getCurrentConditions().attribute crashes when data is not available SDK 3.2.1
I am using the brand new shiny SDK 3.2.1 weather feature which I absolutely love. However, I was dismayed when my watch face crashed in the simulator after I unchecked the "Weather Data Available" box in the settings. I was calling Weather.getCurrentConditions().temperature, and I got an unexpected type value error. When I called Weather.getCurrentConditions() instead, it recognized it as a null value and I could use an if statement to work around it. I have not tested the other weather functions or attributes.
Can the attributes for the weather functions get null values when data is not available? Thanks
    Former Member in reply to jim_m_58
    Hi Jim,
    What you're doing there is similar to my workaround, although I am not following your use of makeTemp.
    Here's my full function:
    	static function getTemperature() {
    		var value;
    		var degreeSign = StringUtil.utf8ArrayToString([0xC2,0xB0]);
    		var units = degreeSign + Ui.loadResource(Rez.Strings.degC);
    		var unitsNum = Sys.getDeviceSettings().temperatureUnits;
    		if (Weather.getCurrentConditions() == null) {
    			value = "-- ";
    			if (unitsNum == 1) {
    				units = degreeSign + Ui.loadResource(Rez.Strings.degF);
    		else {
    			value = Weather.getCurrentConditions().temperature;  // units are degC
    				value = ((value * (9.0d / 5.0d)) + 32).toNumber();
    		var reading = value + units;
    		return reading;
    The app crashes when I try this:
    if (Weather.getCurrentConditions().temperature == null) {
    // do something
    I'm relatively new at coding and Connect IQ. Is this behavior normal for attributes?
  • Not sure I understand.  Are you null checking what you get when you call getCurrentConditions()?  Just tied unchecking "weather data available with this code, and I get "No Conditions" displayed
        	var temp="No Weather";
        	if(hasWeather) {
        		temp="No Conditions";
        		var cc=Weather.getCurrentConditions();
        		if(cc!=null) {
        			temp=makeTemp(cc.temperature).format("%0.1f")+degree;
        	//display the temp variable
