Complete
Not a bug.
Weather.getCurrentConditions().attribute crashes when data is not available SDK 3.2.1
I am using the brand new shiny SDK 3.2.1 weather feature which I absolutely love. However, I was dismayed when my watch face crashed in the simulator after I unchecked the "Weather Data Available" box in the settings. I was calling Weather.getCurrentConditions().temperature, and I got an unexpected type value error. When I called Weather.getCurrentConditions() instead, it recognized it as a null value and I could use an if statement to work around it. I have not tested the other weather functions or attributes.
Can the attributes for the weather functions get null values when data is not available? Thanks
  • Not all devices with 3.2 have Weather (the f5+ for example).
  • Dear Jim, may I please ask? I see in ERA that users of my watch have the same error with weather, because I did not implement the check for Weather module. How is this possible, if I set in manifest that Minimum SDK version is 3.2.x, then all users should have watch firmware compatible with 3.2.x and therefore should have Weather module. As for hardware, I am supporting only Fenix 6X and Tactix Delta. So is it possible that someone can install the Watch face and may not have proper support for Weather module on his watch? Or could there by any other cause that weather is not populated into variables?
  • Not all of the 3.0 devices have 3.2 and some didn't get 3.1 (like the Oregon).  In the sim, it's only a few, like the va4, va4s, va3m and venu, but some devices just got 3.2 like the fr945 with the 5.00 FW that rolled out last week.
    Former Member in reply to Former Member
    Actually, I just saw the list of device compatibility on the Developer page. The version compatibility is listed as 1.0, 2.0, 3.0. I assume all devices listed under 3.0 are compatible with 3.2.0?
    Former Member in reply to Travis.ConnectIQ
    Thanks Travis and Jim! This is very helpful. It makes sense that null.attribute would return an error. When I first saw all the features in the weather module I was impressed. You guys are doing a great job. Some significant improvements indeed.
    Question -- How do I know whether a device has 3.2.0 support without running the has check?
