My watch face (https://apps.garmin.com/en-US/apps/d44a137e-7a1e-4b67-9aa6-133d48db745c) is crashing when using one function on some watches, Forerunner 45 and Fenix 7s that I could get feedback from. When I try in the simulator for those watches, it works fine and it also works fine on other watches, like Forerunner 645 (that I own).
This is the code that is crashing, I tried to wrap up everything on try catches without luck. I am starting to get multiple complaints.
Here is the offending code, I was able to confirm the function getHRMax is working if used alone (via other functionality of my watch face).
//! Get the VO2Max. Try first from watch, then calculate.
//! @return [Float] Floating number with VO2Max approximation
function getVO2Max() {
var vo2max = null;
var profile = null;
try {
profile = UserProfile.getProfile();
catch(ex) {
// RFCS-64 2022/7/24 - Check if can get VO2Max from watch directly
if (null != profile && profile has :vo2maxCycling && profile has :vo2maxRunning) {
try {
// RFCS-64 2022/7/24 - Check current sport from watch
if (UserProfile.HR_ZONE_SPORT_BIKING == UserProfile.getCurrentSport()) {
vo2max = profile.vo2maxCycling;
else { // RFCS-64 2022/7/24 - Any other sport, get running VO2Max
vo2max = profile.vo2maxRunning;
catch (ex) {
// If could not get the watch VO2Max, try to calculate
vo2max = RunFocusData.calculateVO2Max();
else {
// If version of the watch does not have VO2Max exposed, calculate
return vo2max;
//! Calculate current VO2Max based on simple formula to give approximation
//! VO2Max = ( HRmax / HRrest ) * 15.3
function calculateVO2Max() {
var rhr = null;
var hrmax = null;
var vo2max = null;
var profile = null;
try {
catch(ex) {
finally {
// RFCS-64 2022/7/24 - Watch API does not have VO2Max exposed, calculate
if (null != profile) {
try {
rhr = profile.restingHeartRate;
catch (ex) {
finally {
if (null != rhr) {
try {
hrmax = RunFocusData.getHRMax();
catch (ex) {
if (null != hrmax) {
try {
// RFCS-64 2022/7/24 - Make sure it converts to float
vo2max = Math.round((hrmax.toFloat() / rhr) * 15.3);
} catch (ex) {
vo2max = null;
return vo2max;
// RFCS-69 2022/7/24 - Trying to make sure it doesnt crash
//! Get HRMax from HR zone 5
//! @return [Number] HRMax
function getHRMax() {
var HRMax = null;
var genericZoneInfo = null;
try {
genericZoneInfo = UserProfile.getHeartRateZones(UserProfile.HR_ZONE_SPORT_RUNNING);
// RFCS-69 2022/7/24 - An array was returned and it has at least one element
if (genericZoneInfo has :size && genericZoneInfo.size() > 0) {
HRMax = genericZoneInfo[genericZoneInfo.size()-1];
catch (ex) {
return HRMax;
I wonder if anyone is experiencing the same or may have an idea of what is going on. It looks similar on reports about using Moment.subtract as reported here https://forums.garmin.com/developer/connect-iq/i/bug-reports/runtime-error-with-moment-subtract-when-subtracting-a-duration but maybe some other function?
Remember, it is working fine on simulator and other watches, only on some watches that it doesnt work.
enbrandao
in reply to flowstate
Cancel
Vote Up
+1
Vote Down
More
Cancel
Comment-
enbrandao
Cancel
Vote Up
+1
Vote Down
More
Cancel
Children
