My watch face (https://apps.garmin.com/en-US/apps/d44a137e-7a1e-4b67-9aa6-133d48db745c) is crashing when using one function on some watches, Forerunner 45 and Fenix 7s that I could get feedback from. When I try in the simulator for those watches, it works fine and it also works fine on other watches, like Forerunner 645 (that I own).
This is the code that is crashing, I tried to wrap up everything on try catches without luck. I am starting to get multiple complaints.
Here is the offending code, I was able to confirm the function getHRMax is working if used alone (via other functionality of my watch face).
//! Get the VO2Max. Try first from watch, then calculate.
//! @return [Float] Floating number with VO2Max approximation
function getVO2Max() {
var vo2max = null;
var profile = null;
try {
profile = UserProfile.getProfile();
catch(ex) {
// RFCS-64 2022/7/24 - Check if can get VO2Max from watch directly
if (null != profile && profile has :vo2maxCycling && profile has :vo2maxRunning) {
try {
// RFCS-64 2022/7/24 - Check current sport from watch
if (UserProfile.HR_ZONE_SPORT_BIKING == UserProfile.getCurrentSport()) {
vo2max = profile.vo2maxCycling;
else { // RFCS-64 2022/7/24 - Any other sport, get running VO2Max
vo2max = profile.vo2maxRunning;
catch (ex) {
// If could not get the watch VO2Max, try to calculate
vo2max = RunFocusData.calculateVO2Max();
else {
// If version of the watch does not have VO2Max exposed, calculate
return vo2max;
//! Calculate current VO2Max based on simple formula to give approximation
//! VO2Max = ( HRmax / HRrest ) * 15.3
function calculateVO2Max() {
var rhr = null;
var hrmax = null;
var vo2max = null;
var profile = null;
try {
catch(ex) {
finally {
// RFCS-64 2022/7/24 - Watch API does not have VO2Max exposed, calculate
if (null != profile) {
try {
rhr = profile.restingHeartRate;
catch (ex) {
finally {
if (null != rhr) {
try {
hrmax = RunFocusData.getHRMax();
catch (ex) {
if (null != hrmax) {
try {
// RFCS-64 2022/7/24 - Make sure it converts to float
vo2max = Math.round((hrmax.toFloat() / rhr) * 15.3);
} catch (ex) {
vo2max = null;
return vo2max;
// RFCS-69 2022/7/24 - Trying to make sure it doesnt crash
//! Get HRMax from HR zone 5
//! @return [Number] HRMax
function getHRMax() {
var HRMax = null;
var genericZoneInfo = null;
try {
genericZoneInfo = UserProfile.getHeartRateZones(UserProfile.HR_ZONE_SPORT_RUNNING);
// RFCS-69 2022/7/24 - An array was returned and it has at least one element
if (genericZoneInfo has :size && genericZoneInfo.size() > 0) {
HRMax = genericZoneInfo[genericZoneInfo.size()-1];
catch (ex) {
return HRMax;
I wonder if anyone is experiencing the same or may have an idea of what is going on. It looks similar on reports about using Moment.subtract as reported here https://forums.garmin.com/developer/connect-iq/i/bug-reports/runtime-error-with-moment-subtract-when-subtracting-a-duration but maybe some other function?
Remember, it is working fine on simulator and other watches, only on some watches that it doesnt work.
