Complete
over 4 years ago
WERETECH-8010
Fixed
Vivoactive 3 firmware 6.90 cause watch faces to crash
Please check the newest firmware for issues that causes watch faces to crash.
e.g. https://apps.garmin.com/de-DE/apps/fc3f9b9f-add6-46cb-8e0b-9a2172a04c31
All vivoactive 3 users with the latest firmware are reporting the same affect, the watch face crashes directly. No start is possible.
No crash error logging is written into the log file of the watch.
The simulator of the SDK works perfectly with the watch face (3.0.12/3.1.4) and the last issues caused by the watch face was reported a year ago.
Thanks for support and please keep up testing your software.
The Magician
Parents
  • Knowing that two of mij widget crashed and having tried al solutions I could think of (including generating a new app-id), I first tried if an empty widget would work. I made a new project with another name in Eclipse and verified that id did not crash (and it didn't). Next i copied and pasted entire functions from the original sourcecode to the new project.(renamed classes as i went) and I copied resourcefiles.  In between I verified that it still worked (which by the way once did not when i copied an entire sourcefile to the new project). Of course I hoped that on the way I would discover which part of the source caused the crash, but none did.I ended up with a working widget that was almost identical to the original one. Only difference is I did not copy some unused resources and I used some other names for classes (and the entrypoint in the manifest). I did the same with another widget and got it working that way. Weird ... . Can't think of an explanation.
Comment
Children
