Acknowledged
Venu2 Apps auto-closing after inactivity from background or glance launch
Applications launched from the glance or from a background delegate close after inactivity.
If this is by design there should be some control over this. I'm running into this with my own app, but have also observed it on the 'WatchiBeastie" app from GarminLabs. (when you are low on "health" you need to do 100 steps, but unless you are actively keeping the watch engaged during those 100 steps, the app will close and the counter will be lost).
When apps are launched from the activities/apps menu. They don't have this issue.
  • Where in the documentation or description of the watch models can I read about these background service time limits?
  • You can reorder things in the app list - press on the app and you get a menu with things like "set as favorite" and "reorder, or maybe just the option to reorder (depending on watch)  So it shows right away when you go to the list
    If launched from a glance, there is no way to avoid the timeout other than interacting with the app before it times out.  Even if your app doesn't handle something like a tap, a tap resets the timeout.  I first asked about this about 9 years back when I did my first widget.
  • The app is a device app, but I've had users request that it be given a glance to be easier to launch. This is likely related to new installed device apps being dead last by default in the apps view. So it's a pretty common issue when users are installing their first app, that they fail to find it easily.
    Even more than the glance, the background launch having this timeout is unfortunate, if you want to launch a tooth brushing timer at night time, it can't stay open long enough to actually do it's job for example. Or for example the current WatchiBeasties app tries to get you to do a few things at the end of the day, and you can't actually complete them because it was launched from the background.
  • This is normal (since CIQ began) and expected on watches.
    When something is launched from the widget or glance loop, it times out after 1-2 minutes and closes (time depends on which watch)
    On an edge, it won't time out - (at least the ones I've tried)
    You will not see this in the sim - there, they never time out
    As you see, launching from activities has no issue Sounds to me like you may want to make this a device app, not a widget, and remove getGlaceView from your app base.
